amp install
windtech007
Posted: February 13, 2005 at 4:13 PM / IP Logged
I have a 97 toy tacoma
would like to install pioneer  deh-6600 headunit,gm-x862 amp, ts-a1680r 220w 6.5 front spk,and ts-a6980r 350w 6x9 rear spk
i have na idea how to wire them or evan if you can    could someone please help?
Alpine Guy
Platinum - Posts: 2,478
Posted: February 13, 2005 at 4:18 PM / IP Logged
I definately reccomend bringing it all to a shop and get it installed properly, then study how they did it so you can take a shot at it in the future.  But for now, definately get it done professionally.
windtech007
Posted: February 13, 2005 at 4:52 PM / IP Logged
ok thanks
But I was looking for a diagram. I was hoping that maybe someone could draw a simple diagram on connections for amp to speakers.
KarTuneMan
Platinum - Posts: 7,056
Posted: February 13, 2005 at 11:29 PM / IP Logged
The deck comes with a "diagram" as does the amp.
I think you should have help as well. Pay for an install on your truck, and work on a friends car for some education.
rickfordfosgate
Posted: February 14, 2005 at 3:17 AM / IP Logged
i think the diagram that u want are very simple... the amps should have 4 channel to drive 4 speaker that u have. 2 channel drive your ts-a1680r 220w 6.5 front spk and 2 channel ts-a6980r 350w 6x9 rear spk.
about the power connection, it is simple. a single amps have 3 terminal that is DC 12v, acc remote and the ground. the dc terminal is direct from + terminal from battery and the remote is from acc in the car. this acc will work after the ignition is on. after that ground terminal u can connect from the body chasis.
just connect the head unit to the input amps and connect to the speaker..ok
rick engineering
windtech007
Posted: February 14, 2005 at 3:41 AM / IP Logged
Thanks for the info. The diagram from pioneer shows a two speaker conf, atwo speaker one sub conf,and a four spk one sub conf. My problem is I dont use a sub. According to Pioneer diagram I will need a cap and or a resitor maybe a diode in order to bridge,but it doesnt give specifics. So can you run just four spk and if you cant what do you do with the other two? Will the head unit run two spk plus the amp? Or do I get another amp and split the signal from the head unit.
Any way if I knew a pro installer I would already be rocking down the highway. No really I do appreciate the information.
Thanks,
Windtech007
stevdart
Platinum - Posts: 5,816
Posted: February 14, 2005 at 6:01 PM / IP Logged
Will the head unit run two spk plus the amp? Or do I get another amp and split the signal from the head unit?
Your 2-channel amplifier is capable of powering a pair of speakers.  You can use if for the front pair and still power the rears with deck power.  Run a set of RCA's out of the deck to the amp.  The deck will supply line-out signal to the amp and speaker level signal to the rear pair.  If, after you set the system up like this, you find that the overall volume should be louder...or that you can't find satisfaction with the sound from the rears...you can get another small two channel amp for them and split the RCA's.
If a subwoofer is in your future plans, you might consider the second amp being a 4-channel.  Buy a single voice coil 4 ohm sub.  The 2nd amp could then power a pair plus the sub.
Crutchfield's has some good online tutoring in helping you set up a system.
