Comparo time
T.Hill
Copper - Posts: 268
Posted: February 18, 2005 at 1:47 PM / IP Logged
I've got 2 12" fosgate punch hx2's sealed running 1000watts off a MAAudio SY5011DX @ 1ohm. With the same amp would a 15" XXX in a ported box some where around 32-35hz have more spl. The box would be whatever they recommend like 4cuft. I do have a 1 farad cap with the amp too. Thanks in advance.
Pioneer DEH-P980BT, Zapco DCREF1000.4,Pioneer TS-C520PRS, Adire Extremis, MTX TA91002, TC Sounds TC-3000 15"
forbidden
Platinum - Posts: 5,354
Posted: February 18, 2005 at 2:06 PM / IP Logged
I would think the 1 15" in the ported enclosure just may give you an increase in ouput and depth with more amplitude at that depth.
kfr01
Gold - Posts: 2,121
Posted: February 18, 2005 at 2:20 PM / IP Logged
The cap will add at least 23.565db. (not serious).
Model it up in WinISD or any other enclosure modeling software. It'll tell you. Just a guess - I highly doubt the 15" will be any louder above 40hz. The port will help fill out the bottom end of the 15".
Why don't you post the specs on both subs and I can give you a better guess.
New Project: 2003 Pathfinder
T.Hill
Copper - Posts: 268
Posted: February 21, 2005 at 9:47 AM / IP Logged
Sorry it took me so long, my computer was on the fritz.
       XXX        HX2
Fs:    28hz        29hz
Qts:   .49        .48
Vas:   123.3L      75L
Xmax: 32mm        14mm(both one way)
Sen:   88.7db      88db
Power: 1600/2500   500/1000
These are the specs I could find. Where can I find that WinISD program to download and how to use it. Thanks again.
customsuburb
Gold - Posts: 1,813
Posted: February 21, 2005 at 10:49 AM / IP Logged
The website for winISD is www.linearteam.dk
T.Hill
Copper - Posts: 268
Posted: February 21, 2005 at 11:38 AM / IP Logged
I tried to download it here at work but it won't since they try to restrict downloading anything to the work computers. I'll have to wait til I get my home computer back from the shop.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
