2000 denali sub and amp install
djryanl
Posted: March 05, 2005 at 6:31 PM / IP Logged
I am installing an arc audio 1000.2 i want to run it bridged mono to power 2 eclipse 12" subs in a sealed box. I hooked the power up correctly but i am having trouble with the sound. The amp has a built in high to low level converter so i connected the wires going to the rear speakers to the amp. I am barley getting any sound out of the subs with the gain at 100% any ideas on what might be wrong?? Also when i press the break petal, hazard lights etc. there is a slight popping noise from the subs.. Thanks for your help
Alpine Guy
Platinum - Posts: 2,478
Posted: March 05, 2005 at 7:11 PM / IP Logged
High level signals such as the ones from you rear speakers are infested with noise.  The factory speaker wires run in a big clump of wires, and noise is radiated through the speaker wires.  In this case i have gained a better signal and volume by installing a quality " adjustable line output converter" directly behind the head unit, and run your rca wires from there to the sub amp.
Tuesday, December 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
