Posted: March 13, 2005 at 12:04 AM / IP Logged
Posted: March 13, 2005 at 12:30 AM / IP Logged
Posted: March 13, 2005 at 12:23 PM / IP Logged
Posted: March 13, 2005 at 7:04 PM / IP Logged
Posted: March 13, 2005 at 11:40 PM / IP Logged
Posted: March 14, 2005 at 12:09 AM / IP Logged
Posted: March 14, 2005 at 9:50 AM / IP Logged
Monday, March 30, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
I carefully designed my box using WinISD and a 3D modeling software called Autodesk Inventor. I laid out full scale templates in my truck to make sure everything fit. I modeled the port to scale. All was good. Then I built "Rev A" of my box. I installed it in my truck and learned that the fit was just too tight. The seat fell flush onto the box (I then posted several posts about jacking up the seat) which was not good at all. I had to reduce the height by over an inch.
The result was that the volume of the box changed from about .85 cubic feet to 0.67 cubic feet. That, in turn, changed my tuning frequency so I had to change my port length in order to maintain my 32 Hz desired frequency. Well, the reduced volume caused the port length to grow so long that it hit the subwoofer.
And, because my box height had shrunk and because one end of my box had an offset in it to clear the hump, my 3" dia port was now too large for the end of the box. A 2.5" diameter port was now the max.
WinISD showed that this reduction in pipe diameter at my tuning volume would require an even longer port. I could make it shorter but I would loose my tuning frequency but then my stinking air velocity through the port was too high. Blaa Blaa blaa. You know the story.
Now, my box is a sealed enclosure.
The tech support guys at Polk promised me that I will not be dissapointed in my MM2104 in a sealed enclosure. I am sure that I will love it just the same but it just kills me that I went to all that trouble to learn about port tuning then ended up not being able to use it.
Dratts!!!
Anyway - thanks to all that have helped me. I'll post some pictures when I get the system installed completly.
Mike
I can save the port tuning for a another project.
Thanks again!
Mike
