hyundai accent
patmar
Copper - Posts: 69
Posted: November 10, 2002 at 9:50 AM / IP Logged
i need  the color code for replace my factory stereo on hyundai accent 2002.
tank to help
pat
djfearny2
Silver - Posts: 810
Posted: November 10, 2002 at 10:25 AM / IP Logged
radio 12 volts ORANGE / black  radio ground . black (chassis),  switched 12 volts - blue/black.   power antenna -pink.   left  front speaker -red +blue-.   right  front speaker- white +  brown-.   left rear- green + orange-.   right rear orange + blue -  here you go this is from deis techsoft program so if it is wrong not my fault check the speaker colors by using a 7.2 or 9 volt batt .. and use a tester to check both constant 12 and switched 12.
Jon
Installer/Help Technician
---coral springs florida---
patmar
Copper - Posts: 69
Posted: November 10, 2002 at 11:17 AM / IP Logged
tanks jon
JellyNutz
Copper - Posts: 85
Posted: November 11, 2002 at 12:12 AM / IP Logged
Pat,
      Use a wiring harness!  They're cheap, and it saves your factory wiring if you ever plan on putting your factory deck back in!
