2005 mustang install
crvz
Member - Posts: 48
Posted: June 07, 2005 at 6:10 PM / IP Logged
It's been a while since i've worked as an installer, and a friend of mine has asked me to help him install some stuff in a 2005 mustang.  I've noticed in the last few years that the ford radios have changed.  Can anyone give me a quick tip in getting the radio out?  I dont want to explore in a buddy's car (but for some reason, i never had a problem figuring it out in a customers car) for fear of something going wrong.  Thanks!
Steven6095
Copper - Posts: 74
Posted: June 07, 2005 at 10:29 PM / IP Logged
Two screws in arm rest (lift it up)
Small black trip peice around shifter
Pull e brake all the way up!! COVER THIS or it will be scratched.
Pop arm rest console up and out over the e brake.
Pull both side trim peices straight out or lifting slightly from the bottom.
You will see from there :) AC control wiring is tricky. Lay down in floor board and you will see release.
Good luck with it all :) .....it wont be fun.............
Running wire or just deck?
http://www.computerservices.bz/car/05mustang.htm
