Parallel or Series?
jaymes
Copper - Posts: 47
Posted: June 11, 2005 at 1:58 PM / IP Logged
heres what i have for the bass in my car.
Lanzar vibe 1600 watt amp
  • 2 x 400 Watts RMS at 4 Ohms
  • 2 x 800 Watts Max at 4 Ohms
  • 1 x 1600 Watts Max at 4 Ohms Bridged
  • 2 x 650 Watts at 2 Ohms
  • Electronic Crossover Network
  • Bass Boost Circuit
  • Bridgeable at 4 Ohms
  • 2 Ohms Stereo Stable
  • Tri-Mode Capable
  • Gold RCA Inputs
  • Line Outs For Left & Right Channels.
  • Power & Protection LED Indicators
  • Advanced Protection Circuitry
  • Soft Turn On/Off
  • Remote Control Bass Booster
    I know i will not get full effencicy from this amp but how how many watts do you think it will actually put out? I am thinking to run it at 4 ohms briged because i have 2 of these:
    Bazooka 12" dual voice coil
    RSW1224DVC
    Power Handling350w - 400w *max power wired in parallel*
    Power Handling with Liquid Cooling500w *max power wired in parallel*
    ImpedanceDual 4 Ohm
    Sensitivity88
    Recommended Power50w - 225w (RMS) per coil
  • My question is should i run it parallel and bridge my amp? or should i run the 2 seperate channels. It says max 1600 watts for the amp at 4 ohm bridged but the subs say Max 500 watts each? I want to run in parallel but do you think it would blow the subs? I know the amp wont reach that power but i dont want to damage anything.. Thanks
  • jaymes
    Copper - Posts: 47
    Posted: June 11, 2005 at 4:41 PM / IP Logged
    anyone?
    tcss
    Silver - Posts: 1,623
    Posted: June 11, 2005 at 4:49 PM / IP Logged
    While I'm not a fan of running separite channels into a dual voice coil woofer , however, with this combination you don't seem to have a choice. with dual 4 ohm coils you either have a choice of 2 ohms ( parallel ) or 8 ohms ( series ) neither would work well if your amp was bridged. Set your amp to mono and run it two chan., one to each coil.
    Blowntweeters
    Silver - Posts: 650
    Posted: June 11, 2005 at 5:47 PM / IP Logged
    do you have 1 or 2 subs  and the sub/s  dual 4 ohm or dual 2 ohm  if you have to right  impedance  i would run it 4 ohms mono
    1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
    Blowntweeters
    Silver - Posts: 650
    Posted: June 11, 2005 at 5:50 PM / IP Logged
    i think about 600 to 750 RMS
    jaymes
    Copper - Posts: 47
    Posted: June 12, 2005 at 1:14 AM / IP Logged
    SOrry. Yes i have 2 subs dual 4 ohm (says in the specs).. I am thinkin option 2 here but would it be too much power?
    stevdart
    Platinum - Posts: 5,816
    Posted: June 12, 2005 at 9:57 AM / IP Logged
    Diagram 2 is the correct one to use...and that amp will not overpower those subs.  Don't go by "max" ratings but by RMS ratings, and with amps especially (depending on the brand) they tend to be on the high side, too.  I would believe that Lanzar amp will put out no more than 700 - 800 watts into a 4 ohm bridged load, so this marriage should be fine.  With this setup, you are getting full efficiency out of the amp.  Keep the bass boost off and be precise in setting the amp gain.
