Noise when I plug in iPod adapter
one_stinky_bum
Member - Posts: 10
Posted: June 19, 2005 at 11:54 AM / IP Logged
Hello Folks,
I have a power inverter in my car so I just use my regular iPod home adapter to charge my ipod in my car. I have a problem though - when I am charging the iPod, I get a lot of noise. I can charge my laptop or cell phone while using the iPod (disconnected from the charger) without noise, so I'm thinking the iPod adapter is to blame. I doubt that I can replace it with a "better" one since it works just fine, plus Apple makes only 1 type of iPod adapters.
Anyways, the iPod is hooked up to aux inputs on my avic n1, so I'm thinking about getting a noise filter to put between the ipod and the avic n1.
Would this work? Any recommended noise filters? There are quite a number of them online so picking one with no prior experience gives me a funny feeling.
Thanks folks. I searched the forum, but nobody seemed to have an iPod + inverter case.
Jay T
Copper - Posts: 169
Posted: June 20, 2005 at 11:46 AM / IP Logged
How is your power inverter wired?  Details really help to figure out the problem.  And just to clarify. There is no noise when you're not charging the iPod?
Welcome to the forum.
one_stinky_bum
Member - Posts: 10
Posted: June 20, 2005 at 11:59 AM / IP Logged
My inverter is wired to an ignition controlled 12V source. I only get noise when I plug in the charger... I could be playing music just fine with the inverter on, but as soon as I plug in the charger, it gets noisy.
kgerry
Platinum - Posts: 3,455
Posted: June 21, 2005 at 11:23 AM / IP Logged
you seem to have answered your own question.... try to connect the charger directly to the battery and see if you still have noise.... if you dont then just wire a plug assy directly to the battery.... (make sure to fuse it at the battery)
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
one_stinky_bum
Member - Posts: 10
Posted: June 21, 2005 at 12:32 PM / IP Logged
The charger is the home charger so it needs 120V, hence the inverter.
kgerry
Posted: June 21, 2005 at 1:20 PM / IP Logged
i know, i mean wire the AC inverter directly to the battery and see what happens....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
one_stinky_bum
Member - Posts: 10
Posted: June 21, 2005 at 4:58 PM / IP Logged
Ok, I'll give that a shot.
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
