poor AM reception
tinter
Member - Posts: 8
Posted: June 20, 2005 at 2:48 PM / IP Logged
2001 panasonic deck- great fm reception, but very poor am reception, is it the install, or the HU?its in a 2001 hyundai accent. thank you
homer1
Copper - Posts: 62
Posted: June 20, 2005 at 2:57 PM / IP Logged
Check antenna ground - makes big difference for AM
Experience gained is directly proportional to the amount of equipment destroyed - break it & learn!
kgerry
Platinum - Posts: 3,455
Posted: June 21, 2005 at 10:44 AM / IP Logged
plug another antenna into the unit and give it a listen...... AM reception is critical to a good antenna source, whereas you'll pick up FM without an antenna even plugged in in many cases ( it'll picket fence a bit, but you'll get reception)
thats not to say it may not be a problem in the tuner front end of the radio, just not as likely... easy quick test is just to plug in a test antenna you buy for 10 bucks... if it works good with the test antenna, you have an antenna problem on the vehicle, if it doesnt, you've likely got a bum front end in the HU.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
uz2bauto
Member - Posts: 42
Posted: June 21, 2005 at 12:35 PM / IP Logged
chassis ground your radio as well as using the ground in your harness. this may help
paint and body
"semi-professional"
Saturday, November 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
