Alternator noise
elvedinUSA
Member - Posts: 8
Posted: July 03, 2005 at 12:00 PM / IP Logged
I just installed an indash dvd and lcd player...but now i have a alternator noise in my system...i tryed changing grounds but it didnt help...
any sugesstions????
dino :)
boulderguy
Silver - Posts: 510
Posted: July 08, 2005 at 1:57 PM / IP Logged
there are about 6 bajillion alternator noise postings, I'd say check those for the fastest solution.  Be sure to check the sticky "proper ground," as that's still probably the problem.  If still no luck, post as much detail about your system as possible, as the above doesn't tell us much.
tcss
Silver - Posts: 1,623
Posted: July 09, 2005 at 2:20 PM / IP Logged
Almost all DVD systems ( especially GM trucks ) with RF modulators that have alt. whine can be cured with a ground loop isolator. They're cheap and easy to test, go there first.
Tuesday, November 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
