How do I add a subwoofer?
BigBurbMan
Member - Posts: 20
Posted: July 05, 2005 at 1:37 PM / IP Logged
I have a Pioneer am/fm/cd receiver (4x50w) in my RV, with two pairs of 6.5" round coax speakers connected, one set for the front, one for the rear.  How do I add a subwoofer?  Do I need a special amp? Crossover?  Any help appreciated.
forbidden
Platinum - Posts: 5,354
Posted: July 05, 2005 at 1:45 PM / IP Logged
Adding sub properly is a combination of things. You need the following matched together properly. Amp, amp wiring kit, sub and box. The box is the single most important part of the system, it will make or break the performance of the sub. By the sounds of things you are not after a system that will annoy the RV par, but one that will fill in the balance of the sound. Find a practical location for mounting the sub box (it must be securely mounted). To keep it simple and under control as far as the $ goes, keep it to a single 10" or single 12" sub. A prefabricated box should fit into your area that you choose. The sub should ideally be s single voice coil 4 ohm sub with a power rating in RMS of between 100 and 400 watts. Peak power is highly misleading so ensure that both the amp and sub are rated in rms power. Next find yourself a 2 channel amplifier rated between 50w x 2 rms and 100w x 2 rms, this amp is perfect for running a sub like this with ease. For a wiring kit, on the small amp with up to a 30 amp fuse, a 10 gauge wire kit is good, over 30 amp I would look at an 8 gauge kit. You more than likely do not need to go bigger than this.
Go to Wal-Mart of all places to purchase the 8 gauge Scosche amp wiring kit. They are uber cheap there for a really good kit that has all you need for wiring the amplifier properly. For your sub / amp / box, I recommend that you head into a local shop that needs and appreciates your business. They are a shop just like me that offers you this kind of advice, advice that you cannot get from the e-tailer to save a couple of bucks.
Poormanq45
Silver - Posts: 597
Posted: July 05, 2005 at 1:57 PM / IP Logged
Hmm, an RV.
I suggest using two subs. One under the bed, and one under the couch.   THat'll make for some good vibrations How do I add a subwoofer? -- posted image. .
ANyway, forbidden pretty much covered it.
Poormanq45
Silver - Posts: 597
Posted: July 05, 2005 at 2:00 PM / IP Logged
ALso, sinse you're working with a relatively large cabin volume you will not get the really high cabin gains that smaller vehicles get. I would recommend that you take a look at getting a single great 15 or two 12in subs. In the proper enclosure you'd definately be able to feel it throughout the vehicle, not just hear it.
BigBurbMan
Member - Posts: 20
Posted: July 05, 2005 at 2:07 PM / IP Logged
Thanks for the info....I actually bought an MTX 8" singe coil sub to replace the factory sub in my '01 Suburban, BUT due to bad info from Crutchfield, it doesn't fit in the factory enclosure.  So I was thinking of trying to wire it up in the RV instead of sending it back.  So if I understand correctly, the receiver needs to have separate outputs for the sub for it to work?
Location depends largely on where I can string the wires.  I'm not looking to shake the entire campground, just add a little more bass than you can get out of a 6 1/2" coax speaker.
Don
Blowntweeters
Silver - Posts: 650
Posted: July 05, 2005 at 3:02 PM / IP Logged
the output you need don't need to be sub output just preamp outputs you will most likly have a set front of and rear preamp output use the rear outputs and if you have a lot of speaker wire between your amp and your sub you will need to run larger wire
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
