99 mercury mystique power antenna
96Fomula
Posted: July 06, 2005 at 12:22 PM / IP Logged
I am not able to get the power antenna to work, is there a trick to get these to work? The antenna works fine with the factory radio but I am unable to get it to work by jumping 12 volts to the white wire on the factory harness. I noticed a factory relay in the trunk attached to the antenna with a plug and two wires going to the actual antenna. This car has an amp under the glove box but is not marked Premium Sound anywhere. Does anyone have a diagram for this car?
Thanks for the help!
chungo
Copper - Posts: 135
Posted: July 06, 2005 at 6:10 PM / IP Logged
check the blue/red wire
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
