1999 Nissan Altima Amp Install
Cartdawg
Posted: July 08, 2005 at 1:27 PM / IP Logged
Hey guys....i'm about to install an amp in my Nissan...And I was just curious if anyone knew where a grommet under the hood might be located in my Altima so that I could get the  power wire thru to the inside.  Is there a car diagram somebody knows of that I could look at?  Or does anyone know where one might be off the top of their head?
I've looked under the hood...and I dont really see one...also on the inside under the carpet....theres that black plastic type lining all over the floorboard.........so its like......yay!
Anybody know a solution to make this easy as pie?  I know how to install the thing...just wondered if anyone knew anything more so I didnt have to fish the dang wire thru the wheel well panel.
Thanks!
Blowntweeters
Silver - Posts: 650
Posted: July 09, 2005 at 3:57 PM / IP Logged
drill a hole if you dont want to put it threw the fender  well also check the right side of the master cyl. for a grommet  if you still can.t find one drill a hole just be careful not to drill into anything
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
Tuesday, April 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
