Install Schematics
sk8terchick4241
Posted: July 28, 2005 at 10:45 AM / IP Logged
Wondering if anyone knows of a good website that provides install schematics or if anyone can give me some install info (such as a wiring diagram) for some subs and an amp i just got. Info...
Car= 1996 Eclipse
Subs= 2- 10" Pioneer 450w IMPP in a Pro Bend Competition Bandpass r/t box
AMP= Jensen- 2/1 channel... 500watt...2 ohm stable (mosfet power supply, xa2125)
P.S. The box was given to me and the amp is drilled into the back of the box, is that the best place for it to live or would it be more productive if i put it under the seat or something?.. sorry i know nothing about systems and any help would be appriciated. thanx
haemphyst
Platinum - Posts: 5,059
Posted: July 29, 2005 at 5:16 PM / IP Logged
Here's your wiring diagram...
The amp just needs a battery lead - an 8 gauge kit would be PLENTY for that amp... follow the instructions included in the kit, but basically, BIG blue wire from battery + to + terminal on amp, and silver wire from chassis to - terminal on amp, small blue wire to blue wire in dash - either the one on the deck labelled remote (if aftermarket), or the switched 12v in the dash.
Since your amp is already "installed" - leave it where it is... make your life easier.
Pretty simple really, but if you need more help, let us know!
Francious70
Silver - Posts: 629
Posted: July 29, 2005 at 5:52 PM / IP Logged
Well hello sk8terchick, listen to much Avril?? Stick around, you may enjoy it here.
Paul
rottenbelly
Copper - Posts: 99
Posted: July 29, 2005 at 10:30 PM / IP Logged
make sure u bolt or strap the box down in case u are a stunt driver like me. other wise it could slide around and pull wires lose since amp is on box
rottenbellys 05 crew cab colorado.Pioneer dehp 880prs, kenwood excelon in all 4 doors. Bazooka 500 mono Jl 10w3 in coustom center console box.
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
