05 Dodge Dakota, Alpine CDA 9835 Wiring
3l33t
Posted: July 31, 2005 at 10:17 PM / IP Logged
Hello All, I have an 05 Dakota that I'm trying to install an Alpine CDA 9835 into. I have a wire harness for the radio; however the stock Dodge connector doesn't have a wire going to where the ignition wire is on the harness (red). So my question is where am I supposed to connect that wire to so that it will turn on. Also, this deck says that it requires a direct connection to the battery, is this really necessary or can it be tied into the +12V battery behind the dash? Thanks a lot for the help guys, I really appreciate it!
stevdart
Platinum - Posts: 5,816
Posted: July 31, 2005 at 10:25 PM / IP Logged
Yes, it's necessary to follow the manufacturer's instructions.  Run a 10 gauge wire directly to the battery.  Find a place where you can snake it through a grommet in the firewall, and use a fuse as directed in the instructions.  The switched red wire can go to any 12 volt switched source under the dash.  Use a multimeter set to DC volts, and probe connections using the key to turn on/off the ignition.  The switched source will go off when the key is off.
3l33t
Posted: August 01, 2005 at 8:28 PM / IP Logged
I got er done :) Hooked the switched 12V into the 12V utility outlet. Thx
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
