01' Maxima bose system
solidvision
Posted: August 04, 2005 at 9:07 PM / IP Logged
I am trying to integrate an aftermarket system into the maxima w/o replacing the door speakers, or using an integration kit.  Is this possible, and if so how do you do it?
I want to use an eclipse 3520 for the door speakers,  a kenwook KAC9102D to power 2power acoustik fubar 12's (I know I need a 1ohm amp, but can't offord one.) and for the deck I have a Dual XDMR7700.
Also, If anyone could provide the audio wiring guide to a 2001 Nissan Maxima or basic instructions of installing the entire aftermarket system with new door speakers and the works Please help me!!  I don't have much money, but need to have a system in my car.
geepherder
Platinum - Posts: 3,668
Posted: August 05, 2005 at 9:38 PM / IP Logged
If you need to integrate your new deck w/o replacing the door speakers, you'll need to keep the bose amps in place.  Don't try to use your eclipse amp on those factory speakers.  Solder male RCA ends to the speaker leads of your metra harness.  This way you'll be able to feed the bose amps a low level signal.  Power up the factory amp turn on lead (sometimes blue/white, sometimes blue) in the harness using the blue/white from your head unit, and you should have sound.  Since your deck only has two sets of preouts per the specs, you'll need two y-adapters to hook up the sub amp.
