2001 mazda millenia bose
abner14
Posted: August 25, 2005 at 1:45 PM / IP Logged
I have a 2001 millenia, im going to install a avic n2. the original deck in my car is a bose and i heard  that i have to buy some adapter or rewire everything does anyone know.
Nano tech
jettagli03
Copper - Posts: 311
Posted: August 25, 2005 at 2:13 PM / IP Logged
you'll need a LOC ( <- website to Basic Car Audio explaining what one is) - line out converter since it's bose and doesnt have rca pre-outs. those just tap into your speaker wires and create an rca signal so you can connect it to your amp all nice and easy. you can pick one up from your local radio shack or best buy or whatever you have in your area for pretty cheap.
abner14
Posted: August 25, 2005 at 2:29 PM / IP Logged
thanks that will make it a lot easier to install
Nano tech
abner14
Posted: August 25, 2005 at 4:37 PM / IP Logged
I called best buy and radio shack and they don't know what one is. I called a  audio place and they told me about something called oem adapter does anyone know what that is, im  not an audio tech so im new to this
Nano tech
hookdatup
Posted: August 25, 2005 at 8:45 PM / IP Logged
why would he need a LOC to put the deck in?  in fact, in some later model Mazda BOSE systems there is actually an amp turn on wire in the radios wiring harness that allows you to play through the bose without interfaces or rewiring. If not, an interface such as an install edge psi2 or a PAC bose interface can be used and wired directly to the mazda wiring harness to change the ouput levl of the deck to an acceptable level for the BOSE amps.
Hurry up and plastic weld that before the boss sees it!
