Q: single 12sealed, or 2 12 isobaric
aaronk
Member - Posts: 12
Posted: September 06, 2005 at 7:28 PM / IP Logged
My friend picked up two 12" JL W0 - 8ohm and an amp. Wants me to put them in for him. So Im building a box.
Should I go with one 12" @ 8ohms sealed, or two in an isobaric box @ 4ohm?
They say you get the same general performance, but im guessing thats running both setups at 4ohm???
The reason behind it is space. Right now they are both in a sealed box and it takes up 2/3 of the trunk (3cu.ft.). Thats why its either one single or two isobaric... Since we have two speakers and an amp already, I jsut figured might as well use both speakers and load down the amp to its rated 4ohms...
Suggestions?
[IMG]https://www.the12volt.com/images2/sealed.gif[/IMG]
[IMG]https://www.the12volt.com/images2/isosealed.gif[/IMG]
[IMG]https://www.the12volt.com/images2/isocompsealed.gif[/IMG]
[IMG]https://www.the12volt.com/images2/isobacksealed.gif[/IMG]
[IMG]https://www.the12volt.com/images2/isoplanarsealed.gif[/IMG]
DYohn
Platinum - Posts: 10,741
Posted: September 06, 2005 at 8:25 PM / IP Logged
Isobaric loading will cut the Vas in half (approximately, but close enough) so the net enclosure size is half what it would be for one woofer.  Clam-shell mounting is the easiest to do (woofers mounted facing each other, and wired out of phase with one another.)  Make sure you seal the two woofers together.  Efficiency will be 3db lower than a single woofer, although net output is about the same as one woofer.  If enclosure size is a consideration this can be a good way to go.
Silvrefox
Copper - Posts: 126
Posted: September 06, 2005 at 9:30 PM / IP Logged
DYohn, along the same line of question, does that also work in vented boxes as well? My issue is in a S-10 single cab with 2 12" solobarics. I'd like to go ported, purely for the challenge, and the way I figure it, a single 12 in a vented enclosure is about 3 cubic foot. If what you're saying is right, I could pull it off with 1.5, but what about the vent itself? Also in half?
boosh!!
haemphyst
Platinum - Posts: 5,059
Posted: September 07, 2005 at 7:24 AM / IP Logged
fox...
No, a vented enclosure is a Helmholtz resonator, and it cannot be simply halved. If you halve the box volume, your vent volume grows by approximately twice! Usually it is not space efficiency that mandates a vented isobaric loading, but the fact that many of the non-linearities in the system are removed, DUE TO the isobaric loading.
Generally speaking, there are two reasons to go isobaric:
1: Enclosure volume is halved.
2: VERY high linearity.
Since you asked specifically about the enclosure volume, and I have already explained that this usually is detrimental to vent volume, i.e. it gets too big to be easily implemented, this only leaves reason 2 for you. Could you go sealed? It'd make your life a whole lot easier!
DYohn
Posted: September 07, 2005 at 8:33 AM / IP Logged
You can build any enclosure type you choose with isobaric mounted woofers, but as haemphyst says it is not a simple halving for any enclosure alignment except sealed and ports work differently altogether.  You need to cut the Vas in half and calculate the proper enclosure specifications.  This site has a decent port length calculator once you decide what your enclosure size and tuning frequency needs to be.
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
