Wiring
Lamboman316
Posted: December 04, 2002 at 9:18 PM / IP Logged
I have 2 amps, a distribution block for a double amp system and I also have a capasitor.  Now just run 1 wire out of the block to the capasitor and then 2 off the capasitor one to each amp? The other side of the block wouldn't be needed??  The capasitor is big enough for both amps. Is this the way to go, or is there a better way.
Keep on a Rockin!!
bberman1
Gold - Posts: 2,314
Posted: December 04, 2002 at 10:20 PM / IP Logged
If you’re running one wire to the cap why do you need the distro block?  But as far as running the 2 amps off the cap there is nothing wrong with that. Just be sure to keep the cable’s going from the cap to the amp under 18 inches. From your set up above you are running things correctly although I don’t understand your distro block. I would  put the distro after the cap and then go to your 2 amps just keep it all under 18 inches
bberman1
Gold - Posts: 2,314
Posted: December 20, 2002 at 7:29 PM / IP Logged
correct !
beerstud136
Copper - Posts: 100
Posted: December 20, 2002 at 9:42 PM / IP Logged
why not run the cap to the block, then off the block to the amps?
----- cap ---- block ====== amps
bberman1
Gold - Posts: 2,314
Posted: December 20, 2002 at 10:21 PM / IP Logged
Isn’t that what I said above?
beerstud136
Copper - Posts: 100
Posted: December 21, 2002 at 12:34 AM / IP Logged
my bad
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
