GM 9 Pin Aux Adaptor Diagram
rcoppa
Posted: September 23, 2005 at 9:32 AM / IP Logged
I have a 99 grand am with an indash cd player with the seperate tape player below the head unit. They are connected with the 9-pin adapter and I need to find the wiring diagram for this. I want to splice into this and use it for an aux input. I figure if I just leave a tape in the tape player and splice into the analog input wires it will work just fine with rca inputs. Thanks.
kgerry
Platinum - Posts: 3,455
Posted: September 23, 2005 at 10:57 AM / IP Logged
metra GM9-AUX
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
rcoppa
Posted: September 23, 2005 at 1:28 PM / IP Logged
I cant seem to find the Metra GM9-Aux, all I can find is the PIE GM9-Aux or PAC AII GM9-Aux. I bought the GM9-Aux before and it did not work, all I need is a pin out for this adapter so I can tap into the right wire.
DYohn
Platinum - Posts: 10,741
Posted: September 23, 2005 at 1:32 PM / IP Logged
You may need to get the GM wiring diagrams for this vehicle.  Contact a local dealer or order one from General Motors.
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
