dual woofer wiring ?
justtin00j
Posted: October 02, 2005 at 11:55 AM / IP Logged
i have two alpine type-e SVC and a rockford fosgate 600 watt amp.  it has 50w x 2 at 4 ohms, 100w x 2 at 2 ohms, and 200w x 1 at 4 ohms bridged.  i was wondering if i could wire both subs to the bridge them so they would be getting 200 watts.  my amp is a rockford fosgate 201 punch.
Blowntweeters
Silver - Posts: 650
Posted: October 02, 2005 at 12:15 PM / IP Logged
you can run that amp at 2 ohms brigded and get 200 to each sub. just brigde the amp and wire the subs in parralell. be sure to set your gain correctlly.
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
bumpingjeep
Copper - Posts: 149
Posted: October 02, 2005 at 12:18 PM / IP Logged
good luck with that...i reccommend a different amp
1987 Huffy...spinners...two 15's custom mounted to the back
fingaz22
Silver - Posts: 410
Posted: October 02, 2005 at 12:39 PM / IP Logged
what ohm are the subs 4 or 8 ohm? if you over load that amp it will pop! sounds like your stuck 4 ohm stereo or 8 ohm bridged to operate right with out blowing that amp. but another amp would be a good choice
JUST ONE MORE AMP!!!
hu,alpine cva 1005/dva 5205
sound processor,symmetry(first one).
sub amp,power 1000 the terminator.(1992).
subs,spl comp dual 1 ohms.
punch 150hd on a 10" ev.
alotofhighs
bumpingjeep
Copper - Posts: 149
Posted: October 02, 2005 at 12:41 PM / IP Logged
all type e's are 4ohm svc...if they are new
krazykevin
Posted: October 03, 2005 at 2:11 AM / IP Logged
I have the same setup as you justin.  The punch 201s pushing 2 Punch 10's.  I was wanting to do the same thing, run both speakers bridged at 2ohmsin parallel.  But from the way it sounds, it might not be a good idea.
Question:  Can we run like this and set the gain down a bit to where we are getting more than the 50 watts but not overheating the amp?  Can you run like this "IF" you set the gain correctly and get a little better performance over the 50w X 2 setup?
