amp and sub setup
02tahoe
Member - Posts: 7
Posted: October 05, 2005 at 11:45 PM / IP Logged
how do u feel about this setup. The nicest 15" poweracoustik sub with the 2000 watt mono kenwood amp with a custom box in a 2002 tahoe.
stevdart
Platinum - Posts: 5,816
Posted: October 06, 2005 at 10:01 PM / IP Logged
Is it in a '02 Tahoe?
02tahoe
Member - Posts: 7
Posted: October 06, 2005 at 11:01 PM / IP Logged
ya
whitehallmike
Posted: October 18, 2005 at 12:45 PM / IP Logged
Need more information. Single or dual voice coil?  4 or 2 ohm?  Sealed or ported box?  Is the box the correct size for the sub? RMS wattage of the amp.   What are you trying to do?  Wake the neighbors, win competitions, impress your buddies?  What is the rest of your system like, factory stock or aftermarket?
Your car's audio sustem is just that, a system.   It all needs to work together.  Let us know more about your system and what you're trying to accomplish.
Michael
forbidden
Platinum - Posts: 5,354
Posted: October 18, 2005 at 2:10 PM / IP Logged
I feel kind of blah about it, check back later when I feel better after reading a updated post that might have better equipment in it and more info as well.
Ocuriel
Copper - Posts: 141
Posted: October 18, 2005 at 7:00 PM / IP Logged
I'm with forbidden, that equipment is not the best out there, but not the worse either. How much are you looking to spend? what is your main goal? sq, spl, sql, etc...
Saturday, December 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
