infinity dodge amp?
branvw
Copper - Posts: 90
Posted: October 11, 2005 at 9:12 AM / IP Logged
i am working on  04 dodge truck with an infinity sound system, is it possible to keep the original factory amp or will i have to bypass it?  the deck that we are going to install is a ceapy DVD/TV and has much less power if i run new wires straigt to the deck...... can the factory amp be used??? and HOW?
sneakycyber
Silver - Posts: 413
Posted: October 11, 2005 at 9:30 AM / IP Logged
Yes If i remember correctly it is located behind the passenger side air bag.
jstruckman
Copper - Posts: 465
Posted: October 11, 2005 at 10:02 AM / IP Logged
The 04 Infinity amps in the Rams are speaker level in with a regular 12 volt turn on. It is no problem to use the factory amp with a new head unit.
Jazzy
branvw
Copper - Posts: 90
Posted: October 11, 2005 at 10:29 AM / IP Logged
great to konw, how do i go about that???? where would i find a diagram or somthing for wireing? i really want to use the stock amp
jstruckman
Copper - Posts: 465
Posted: October 11, 2005 at 12:58 PM / IP Logged
Standard Metra Dodge harness should be all you need.
Jazzy
branvw
Copper - Posts: 90
Posted: October 12, 2005 at 9:01 AM / IP Logged
so just attach the metra harness and the amp will have a good clean signal?
jstruckman
Copper - Posts: 465
Posted: October 12, 2005 at 9:25 AM / IP Logged
Yes
Jazzy
branvw
Copper - Posts: 90
Posted: October 12, 2005 at 2:55 PM / IP Logged
so i dont need to dig out the factory amp?
Monday, February 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
