2 ohm stereo or 4 ohm mono
bigmikeww
Copper - Posts: 75
Posted: October 27, 2005 at 5:19 PM / IP Logged
i got two subs and they are dual 4 ohm. also a a two channel amp. my question should i hook them up in (parallel/series) and get a 4 ohm load and run the amp bridged. or should i hook the subs to get two 2 ohm subs and run the amp in 2ohm sterio?? what are the pros and cons of each set up???
DYohn
Platinum - Posts: 10,741
Posted: October 27, 2005 at 5:29 PM / IP Logged
The loading on the amplifier will be the same in both cases.  The only pro or con is running the amplifier bridged will ensure a mono signal so both subs receive the same input.  Running in stereo leaves the possibility that one will get a hotter input or an out-of-phase signal from the other.  You want both speakers in a multiple-sub setup to play the same thing.
geepherder
Platinum - Posts: 3,668
Posted: October 27, 2005 at 9:10 PM / IP Logged
That's a good point that I always seem to forget about.
bigmikeww
Copper - Posts: 75
Posted: October 27, 2005 at 10:20 PM / IP Logged
thanks
