Profile AP1200
j_darling2007
Copper - Posts: 210
Posted: November 04, 2005 at 2:30 PM / IP Logged
I am looking into buying the Profile AP1200 to push my two Infinity Reference subs.  It pushes 600 watts bridged into a 4 ohm load, which is what I will be wiring the subs to (they are DVC).  Has anyone worked with Profile.  Are they a good bang for the buck.  I am on a pretty tight budget and it seems to be a pretty good amp.
Any feedback on the amp would be appreciated (good and bad).  Listed below are the specs.
Details:
   » 2-channel car amplifier
   » 200 watts RMS x 2 at 4 ohms (300 watts RMS x 2 at 2 ohms)
   » 600 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)
   » variable filters (low-pass from 50-250 Hz, high-pass from 80-1200 Hz, at 12 dB per octave)
   » variable bass boost (0-12 dB at 45 Hz)
   » wired bass level remote control
   » stereo or bridged mono output
   » Tri-way capable ( Tri-Way Crossover required)
   » preamp- and speaker-level inputs
   » preamp outputs
   » fuse rating: 25A x 3
   » 4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
   » 15-1/4"W x 2"H x 10-1/4"D
   » warranty: 3 years
There are 3 kinds of people in the world, those who can count and those who can't
jasson327
Posted: November 05, 2005 at 1:47 PM / IP Logged
Those amps are fine. no comebacks so far. next pick would be Boss c700 or c900 these rock.
gotskidmarks
customscene
Posted: November 05, 2005 at 2:06 PM / IP Logged
I actually have the California 1200 - things a beast.
Well - my brother has it now... It's the older blue one - and it cranks, let me tell you. I bought it something like 4 or 5 years ago and i've not had any problems with it. No shut downs, or anything. It does run a bit hot sometimes... but I've not had problems.
...Please enter any 11 digit prime number to continue.
