simple amp question
$toreycadillac
Member - Posts: 17
Posted: November 08, 2005 at 4:29 PM / IP Logged
Option 1 (parallel) = 2 ohm load
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono
How would i wire a mono amp in parallel? it shows
simple amp question -- posted image.
Do they make speaker wire like that?  Like one wire that splits into two ends? or would i take two wires and twist them together and hook them into the + and - terminals or solder the one wire into another?
Hornshockey
Silver - Posts: 520
Posted: November 08, 2005 at 4:45 PM / IP Logged
the easiest way is to run two separate pairs of wires from the amp outputs
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
