Amp Isolation
cbdenver
Member - Posts: 15
Posted: December 12, 2002 at 11:24 AM / IP Logged
All,
Another basic question for you: do I need to isolate the amp case from the metal floor?  Seems kind of pointless when the ground wire is attached to the flloor right there too, but thought I would run it by you guys.
Thanks!
ccaudio
Copper - Posts: 52
Posted: December 12, 2002 at 11:33 AM / IP Logged
yes you should because you can ground out the amp if you do that
chasesaccessori
Copper - Posts: 198
Posted: December 12, 2002 at 11:37 AM / IP Logged
Now it depends upon how old the amp is!
The older amps had to be isolated from the chassis for that reason.  The new amps do not need to be, the circuitry is protected.
(owner/installer)
Chase's Accessories
Ridgecrest, CA
in business since 92
cbdenver
Member - Posts: 15
Posted: December 12, 2002 at 11:38 AM / IP Logged
The amp is a RF Punch 400a4 (year 2000 I think).
ccaudio
Copper - Posts: 52
Posted: December 12, 2002 at 11:40 AM / IP Logged
i would to be on the safe side
chasesaccessori
Copper - Posts: 198
Posted: December 12, 2002 at 11:46 AM / IP Logged
Not a problem.  I've installed about a billion of those with no problems.  From about 96 on back is where I would worry about that problem.
(owner/installer)
Chase's Accessories
Ridgecrest, CA
