Amp remote wire ?
cdnref
Member - Posts: 21
Posted: November 14, 2005 at 9:50 PM / IP Logged
Simple question.
I'm doing a little project and I need to know one thing.
Does the amp remote wire NEED a constant 12V [or a little higher?] to work. Or say will around 9-12 Be fine?
Thanks.
-Anderson
cdnref
Member - Posts: 21
Posted: November 14, 2005 at 9:52 PM / IP Logged
If your wondering as to what I'm doing I can post pics later, just that they are on my laptop and thats about 40km away... BUt I can have them up by tomorrow @ lunch.
Sorry for double post, can't edit :(
oxygen65
Silver - Posts: 252
Posted: November 15, 2005 at 1:21 AM / IP Logged
no your amp turn on wire does not need to be an exact 12 volts, you just need some type of power to tell your amp to turn on
dwarren
Posted: November 15, 2005 at 1:36 AM / IP Logged
Are you sure of that? I know amps pull varying amounts amperage from the remote, but I thought the voltage must remain at 12 volts.
oxygen65
Silver - Posts: 252
Posted: November 15, 2005 at 3:16 PM / IP Logged
it is not going to be a consistant 12 volts anyway, say that you have 4 subs runnin off 2 amps at a 1 ohm load without any upgrades to your alternator, battery, or having a cap. your cars voltage is going to drop down no matter what so it is not going to be a consistant 12 volts
cdnref
Member - Posts: 21
Posted: November 15, 2005 at 4:35 PM / IP Logged
{P}So if I throw a led in series with the remote wire than that should be fine?{/p}{P}Led specs...{/p}{P}{TABLE class=MsonormalTable style="BORDER-RIGHT: medium none; BORDER-TOP: medium none; BACKGROUND: white; BORDER-LEFT: medium none; WIDTH: 100%; BORDER-BOTTOM: medium none; BORDER-COLLAPSE: collapse; mso-border-alt: solid windowtext 3.0pt; mso-border-insideh: 1.5pt solid windowtext; mso-border-insidev: 1.5pt solid windowtext" cellSpacing=0 cellPadding=0 width="100%" border=1}{TR style="mso-yfti-irow: 0; mso-yfti-firstrow: yes"}{TD style="BORDER-RIGHT: windowtext 1.5pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: windowtext 3pt solid; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: windowtext 3pt solid; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}Emitted Colour{/SPAN}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/p}{/TD}{TD style="BORDER-RIGHT: windowtext 3pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: windowtext 3pt solid; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #ece9d8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{B style="mso-bidi-font-weight: normal"}{I style="mso-bidi-font-style: normal"}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}Blue{/SPAN}{/I}{B style="mso-bidi-font-weight: normal"}{I style="mso-bidi-font-style: normal"}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/SPAN}{/I}{/p}{/TD}{/TR}{TR style="mso-yfti-irow: 1"}{TD style="BORDER-RIGHT: windowtext 1.5pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: windowtext 3pt solid; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}Size (mm){/SPAN}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/SPAN}{/p}{/TD}{TD style="BORDER-RIGHT: windowtext 3pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #ece9d8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext 1.5pt; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{st1:chmetcnv w:st="on" TCSC="0" Number="1" Negative="False" HasSpace="False" SourceValue="5" UnitName="mm"}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}3 mm{/SPAN}{/st1:chmetcnv}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial; mso-font-kerning: 0pt"} {/SPAN}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/SPAN}{/p}{/TD}{/TR}{TR style="mso-yfti-irow: 2"}{TD style="BORDER-RIGHT: windowtext 1.5pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: windowtext 3pt solid; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}Lens Colour{/SPAN}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial"}{/SPAN}{/p}{/TD}{TD style="BORDER-RIGHT: windowtext 3pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #ece9d8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext 1.5pt; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}Water Clear{/SPAN}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial"}{/SPAN}{/p}{/TD}{/TR}{TR style="mso-yfti-irow: 3"}{TD style="BORDER-RIGHT: windowtext 1.5pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: windowtext 3pt solid; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial"}Peak Wave Length (nm){/SPAN}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}{/SPAN}{/p}{/TD}{TD style="BORDER-RIGHT: windowtext 3pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #ece9d8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext 1.5pt; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial"}465 ~ 470{/SPAN}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}{/SPAN}{/p}{/TD}{/TR}{TR style="mso-yfti-irow: 4"}{TD style="BORDER-RIGHT: windowtext 1.5pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: windowtext 3pt solid; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}Forward Voltage (V){/SPAN}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/SPAN}{/p}{/TD}{TD style="BORDER-RIGHT: windowtext 3pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #ece9d8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext 1.5pt; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}< = 4.5{/SPAN}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/SPAN}{/p}{/TD}{/TR}{TR style="mso-yfti-irow: 5"}{TD style="BORDER-RIGHT: windowtext 1.5pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: windowtext 3pt solid; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}Reverse Current (uA){/SPAN}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/SPAN}{/p}{/TD}{TD style="BORDER-RIGHT: windowtext 3pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #ece9d8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext 1.5pt; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}< = 50{/SPAN}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/SPAN}{/p}{/TD}{/TR}{TR style="mso-yfti-irow: 6"}{TD style="BORDER-RIGHT: windowtext 1.5pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: windowtext 3pt solid; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}Luminous Intensity Typ Iv (mcd){/SPAN}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"} {/SPAN}{/p}{/TD}{TD style="BORDER-RIGHT: windowtext 3pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #ece9d8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext 1.5pt; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}4000-5000{/SPAN}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/SPAN}{/p}{/TD}{/TR}{TR style="mso-yfti-irow: 7"}{TD style="BORDER-RIGHT: windowtext 1.5pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: windowtext 3pt solid; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial"}Life Rating{/SPAN}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}{/SPAN}{/p}{/TD}{TD style="BORDER-RIGHT: windowtext 3pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #ece9d8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext 1.5pt; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial"}100,000 Hours{/SPAN}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}{/SPAN}{/p}{/TD}{/TR}{TR style="mso-yfti-irow: 8"}{TD style="BORDER-RIGHT: windowtext 1.5pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: windowtext 3pt solid; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}Viewing Angle{/SPAN}{/p}{/TD}{TD style="BORDER-RIGHT: windowtext 3pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #ece9d8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext 1.5pt; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}20 Degree{/SPAN}{/p}{/TD}{/TR}{TR style="mso-yfti-irow: 9"}{TD style="BORDER-RIGHT: windowtext 1.5pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: windowtext 3pt solid; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}Absolute Maximum Ratings{/SPAN}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/SPAN}{/p}{/TD}{TD style="BORDER-RIGHT: windowtext 3pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #ece9d8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext 1.5pt; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}( Ta = {st1:chmetcnv w:st="on" TCSC="0" Number="1" Negative="False" HasSpace="False" SourceValue="25" UnitName="?C"}25°C{/st1:chmetcnv} ){/SPAN}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/SPAN}{/p}{/TD}{/TR}{TR style="mso-yfti-irow: 10"}{TD style="BORDER-RIGHT: windowtext 1.5pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: windowtext 3pt solid; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}Max Power Dissipation{/SPAN}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/SPAN}{/p}{/TD}{TD style="BORDER-RIGHT: windowtext 3pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #ece9d8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext 1.5pt; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial"}P{SUB}M{/SUB}{/SPAN}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial; mso-font-kerning: 0pt"} = 80 mw{/SPAN}{/p}{/TD}{/TR}{TR style="mso-yfti-irow: 11"}{TD style="BORDER-RIGHT: windowtext 1.5pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: windowtext 3pt solid; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}Max Continuous Forward Current{/SPAN}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/SPAN}{/p}{/TD}{TD style="BORDER-RIGHT: windowtext 3pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #ece9d8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext 1.5pt; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial"}I{SUB}FM {/SUB}{/SPAN}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}= 30 mA{/SPAN}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/SPAN}{/p}{/TD}{/TR}{TR style="mso-yfti-irow: 12"}{TD style="BORDER-RIGHT: windowtext 1.5pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: windowtext 3pt solid; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt" vAlign=top}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center" align=center}{st1:place w:st="on"}{st1:PlaceName w:st="on"}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial"}Max{/SPAN}{/st1:PlaceName}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial"} {st1:PlaceName w:st="on"}Peak{/st1:PlaceName}{/SPAN}{/st1:place}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial"} Forward Current{/SPAN}{/p}{/TD}{TD style="BORDER-RIGHT: windowtext 3pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #ece9d8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext 1.5pt; mso-border-top-alt: solid windowtext 1.5pt" vAlign=top}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center" align=center}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial"}I{SUB}FP{/SUB} {/SPAN}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}={/SPAN}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial"}75 mA{/SPAN}{/p}{/TD}{/TR}{TR style="mso-yfti-irow: 13"}{TD style="BORDER-RIGHT: windowtext 1.5pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: windowtext 3pt solid; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}Reverse Voltage{/SPAN}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/SPAN}{/p}{/TD}{TD style="BORDER-RIGHT: windowtext 3pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #ece9d8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext 1.5pt; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}5 ~ 6 V{/SPAN}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/SPAN}{/p}{/TD}{/TR}{TR style="mso-yfti-irow: 14"}{TD style="BORDER-RIGHT: windowtext 1.5pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: windowtext 3pt solid; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}Lead Soldering Temperature{/SPAN}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/SPAN}{/p}{/TD}{TD style="BORDER-RIGHT: windowtext 3pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #ece9d8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext 1.5pt; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}240 ° C ( < 5 S ){/SPAN}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/SPAN}{/p}{/TD}{/TR}{TR style="mso-yfti-irow: 15"}{TD style="BORDER-RIGHT: windowtext 1.5pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: windowtext 3pt solid; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}Operating {st1:place w:st="on"}{st1:PlaceName w:st="on"}Temperature{/st1:PlaceName} {st1:place w:st="on"}Range{/st1:place}{/st1:place}{/SPAN}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/SPAN}{/p}{/TD}{TD style="BORDER-RIGHT: windowtext 3pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #ece9d8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 1.5pt solid; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext 1.5pt; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial"}- 25 ° C ~ + 85 ° C{/SPAN}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}{/SPAN}{/p}{/TD}{/TR}{TR style="mso-yfti-irow: 16; mso-yfti-lastrow: yes"}{TD style="BORDER-RIGHT: windowtext 1.5pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: windowtext 3pt solid; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 3pt solid; BACKGROUND-COLOR: transparent; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{st1:place w:st="on"}{st1:PlaceName w:st="on"}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}Preservative{/SPAN}{/st1:PlaceName}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: Arial; mso-font-kerning: 0pt"} {st1:PlaceName w:st="on"}Temperature{/st1:PlaceName} {st1:place w:st="on"}Range{/st1:place}{/SPAN}{/st1:place}{SPAN lang=EN-US style="COLOR: blue; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/SPAN}{/p}{/TD}{TD style="BORDER-RIGHT: windowtext 3pt solid; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #ece9d8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: windowtext 3pt solid; BACKGROUND-COLOR: transparent; mso-border-left-alt: solid windowtext 1.5pt; mso-border-top-alt: solid windowtext 1.5pt"}{P class=Msonormal style="MARGIN: 0mm 0mm 0pt; TEXT-ALIGN: center; mso-pagination: widow-orphan" align=center}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: Arial; mso-font-kerning: 0pt"}- 30 ° C ~ + 100 ° C{/SPAN}{SPAN lang=EN-US style="COLOR: black; FONT-FAMILY: ????; mso-font-kerning: 0pt; mso-bidi-font-family: ????"}{/SPAN}{/p}{/TD}{/TR}{/TABLE}{/p}
Please do not copy and paste from a rich text editor like Microsoft Word. Please copy and paste from a plain text editor like Notepad.
cdnref
Member - Posts: 21
Posted: November 15, 2005 at 4:37 PM / IP Logged
I'm sorry for the above.
The forward voltage is < = 4.5
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
