Type of box for Vega's?
dzelaya18
Copper - Posts: 49
Posted: November 30, 2005 at 7:43 PM / IP Logged
Hey everyone. Right now I have two 12" Cerwin Vega V-Max subs in a sealed enclosure being fed by a Audiobahn A2801T at 4 ohms, 400 and something watts rms. Does anyone have any expierience with these subs? Should they stay in the sealed box, or would they pound harder in a ported or vented enclosure? Sound quality is ok, but I'm curious if on how to pound harder without getting huge amps and tons of subs. I've heard 300 watts and two tens make teeth rattle in the right enclosure and setup, and I'd like to know how to do that in my own car. '00 Civic sedan. Any ideas guys?
youngone
Silver - Posts: 269
Posted: November 30, 2005 at 10:14 PM / IP Logged
it seems that you are looking for some crazy bass. i have a solution, you should build a nice ported/vented box for those things. they should pound hard especially two of them. you need to build them to specs and have them in separate boxes or integrate them into one.
tecnicly a sealed box will have a better sound quality characteristic. BUT a properly built ported/vented box can have the same quality and have a lot more quantity at the same time.
if you want loud go with a ported/vented box. and I'm sure that the guys on here have some good ideas that already have use the subs and have the design right there for you.
and the box you put your subs in is the decider of the way they will perform and sound. hope this helps
Aaron     Type of box for Vega's? -- posted image.
Want to know some good equipment- JL,Adire Audio,Mcintosh,Brax,Helix,Eclipse,JBL,RE,Dimoand Audio,Zapco, pritty much anything DYhon,Forbidden recommend
On the12volt you give some info and you get in
stevdart
Platinum - Posts: 5,816
Posted: November 30, 2005 at 10:55 PM / IP Logged
You have the 2 ohm subs, wired in series for a net 4 ohms, right?  These subs should work and sound best in the small sealed enclosure (for two, 2 ft^3 net airspace stuffed with fiberfill).  Not knowing your setup other than what you described here, you can look for improvement in these areas:
  • box built rigid with bracing, at size ^ and specs ^.
  • box secured with bolts to the car chassis
  • ample and plentiful sound damping in the car, particularly in the sub area
  • good quality mids, 6" or larger, up front to carry the transition of bass to the front soundstage.  crossed-over at about 80 Hz with the subwoofer, this "pulls" the feel of the sub bass to the front.  door locations are good, but with lots of damping.
  • experiment with different placement and/or direction of the sub box
  • ensure both subs are firing simutaneously and in the same direction
  • change the amplifier.  try using a mono subwoofer amp that will supply 800 to 1200 watts at 1 ohm.  wire the subs in parallel for this setup.  you don't need the excess heat and waste of power using a two-channel amp to drive these subs.  and I believe the power is insufficient with what you have to drive these to the level you are looking for.
I  use a CW sub, not the vmax though (the lower-line HED model), in my car.  Small sealed box, stuffed.  I like it.
dzelaya18
Copper - Posts: 49
Posted: November 30, 2005 at 11:53 PM / IP Logged
They are actually the 4 ohm subs. Each sub has its own channel at 200w, so 400 all together.
