Posted: December 14, 2005 at 1:23 PM / IP Logged
Posted: December 14, 2005 at 2:14 PM / IP Logged
Posted: December 14, 2005 at 2:25 PM / IP Logged
Posted: December 14, 2005 at 2:34 PM / IP Logged
Posted: December 14, 2005 at 3:18 PM / IP Logged
Posted: December 14, 2005 at 9:55 PM / IP Logged
Posted: December 14, 2005 at 11:15 PM / IP Logged
Tuesday, May 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Description
# 12 Band Graphic Equalizer w/Power Booster
# 12dB Boost/Cut
# 2 Channel Amplification
# 2 or 4 Speaker Hook-up
# 200 Watts High Power Output
# Front Panel CD Input Jack
# LED Level Meter
# Fader Control
# Frequency Response: 30-20k Hz
# Slim Design
# Output Impedance: 4-8 Ohms
# Sub-Woofer Control Light Illumination
# Dimensions: 5''D x 7''W x 1''H
do you guys thing this will work well? with the amp i'm using? also, i was told that you lose a few db's do to the EQ, is this true?
Another question for you guys is, would buying some $20 ebay components be a bad idea? Or should I just stick to regular speakers for the front?
Thanks in advance for any help that I may receive from this post :).
-gsus
