Fitting 2 15s in a celica
Blowntweeters
Silver - Posts: 650
Posted: December 27, 2005 at 3:45 PM / IP Logged
 i want to fit  2 15" punch HE's. in my wifes 1990 toyota celica we  just got.  the box i have now wont fit . it's sealed and on the lower half of recommended sealed air space.  any idea's ?:
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
Blowntweeters
Silver - Posts: 650
Posted: December 27, 2005 at 5:39 PM / IP Logged
anybody built a custom box for 2 15"s for this car before. and its the model with the trunk not the lift back.
geepherder
Platinum - Posts: 3,668
Posted: December 27, 2005 at 7:18 PM / IP Logged
Sounds like a great opportunity to use some fiberglass.
supradude
Silver - Posts: 915
Posted: December 27, 2005 at 7:55 PM / IP Logged
I guess it's the height that is the problem? I have 15's in my Supra, but it is a hatchback. You should be able to slant the side that the 15's are on and get them in there. I didn't have any problem with the width. Does that make sense?
'85 Toy
Blowntweeters
Silver - Posts: 650
Posted: December 28, 2005 at 9:53 PM / IP Logged
thanks for the ideas. i would like to build a fiberglass enclosure . never used it before. anything i should know before i get started. ????
geepherder
Posted: December 28, 2005 at 10:14 PM / IP Logged
Have a look in the fiberglass forum for some good tips.
Mask off the area you're molding real good.  Wear some old clothes with long sleeves- it's no fun getting resin on your arms, especially if they're hairy.  Make sure you lay down at least 2-3 layers (maybe more depending on what weight mat or cloth you use) before removing the mold from the vehicle so that it doesn't warp and lose it's shape.  Also be sure you don't make it too big to remove from the vehicle.  The smell of resin can really get to you as well as the glass fibers floating around- wear protection accordingly.
Those are the main things I can think of.  Go to the paint section of the hardware store and pick up plenty of cheap bristle brushes, plastic mixing pails, latex gloves, acetone, fiberglass resin and mat/cloth, etc.  You may want to get some extra hardener for the resin.  Make sure the pails you get are the ones with markings on the side so you know how much resin you're using.  I usually mix resin in one pail, and keep some acetone in another to clean my brushes after lay up.
If you get resin from the hardware store in gallon containers, it'll come with two tubes of hardener.  Each tube has 22ml with markings on the side to help you guesstimate how much to use.  A little basic math will come in handy.  The amount of hardener I use varies with the outside temperature.  At 70 degrees F, I use two tubes of hardener for every gallon of resin.  If it's a little cooler outside- 60 degrees or less, it'll take a little longer to cure, so I sometimes use a little extra hardener to speed this up.  If it's a little warmer- 80 or more, it'll cure faster, so I may use a little less.  This may not matter if you're working inside a heated garage- just make sure you have adequate ventilation.
kirktcashalini
Silver - Posts: 492
Posted: December 29, 2005 at 2:35 PM / IP Logged
should always measure before buying a box, or... build the box if you have time and correct tools. you running about 1.75 ft3 or what?
geepherder
Posted: December 29, 2005 at 5:59 PM / IP Logged
Oh yeah, one more thing about fiberglassing- tear the mat by hand rather than cutting it.  This helps blend the individual pieces together better.  Otherwise, you can sometimes tell where one piece ends and another begins.  Good luck.
Blowntweeters
Silver - Posts: 650
Posted: December 29, 2005 at 9:06 PM / IP Logged
  i had the box. just got the car . i am running 2 ft per sub. i did get the box to fit today .but its upside down. i am going to build a fiberglass enclosure when i have the time.
