remove door panels in F-250
tex12gage
Copper - Posts: 83
Posted: December 30, 2005 at 11:59 AM / IP Logged
i'm trying to figure out how to remove the front door panels in a '99 F-250 to replace the 6x8 speakers. I've looked around but I don't see any snaps or anything.
Same problem with the cover in the back behind the door to replace the rear speakers.
tex
forbidden
Platinum - Posts: 5,354
Posted: December 30, 2005 at 6:48 PM / IP Logged
If it is the same as the F150 for body style you need to find the hidden screws. Pop off the top panel at the rear of the door first. It is above the door panel. Once removed it has a hidden screw behind it. Pop up the power window / lock control and look for a second screw hidden in behind there. IIRC that is all the screws there are and the panel should pop up and off.
fingaz22
Silver - Posts: 410
Posted: December 30, 2005 at 6:53 PM / IP Logged
after the retaining screws are removed i believe the panel will have to go straight up not directly out towards you. they have slots that it seats in on the shell of the door and if pulled straight off the mount will be broken.
JUST ONE MORE AMP!!!
hu,alpine cva 1005/dva 5205
sound processor,symmetry(first one).
sub amp,power 1000 the terminator.(1992).
subs,spl comp dual 1 ohms.
punch 150hd on a 10" ev.
alotofhighs
geepherder
Platinum - Posts: 3,668
Posted: December 30, 2005 at 7:14 PM / IP Logged
Yup.
tex12gage
Copper - Posts: 83
Posted: January 04, 2006 at 12:30 PM / IP Logged
Thanks for the replies,
Now, how do I get to the rear speakers. how do I get the panel off in front of them?
tex
geepherder
Posted: January 04, 2006 at 9:52 PM / IP Logged
The top half has to come off first.  Take out the visible screws and it'll unsnap.  You may see some screws for the bottom half now- I can't remember.  Now unsnap that armrest piece and look there as well.  It's been a while.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
