making an external subsonic filter
black78ta
Member - Posts: 31
Posted: December 31, 2005 at 12:55 AM / IP Logged
Hey guys, I've got a question for you.  I just bought my girlfriend a six channel amplifier, but the amplifier does not have a subsonic filter.  I'm going to bridge the last two channels at four ohms to get about three hundred watts.  How can I make a sort of external subsonic filter.  I'm looking for something rather cheap, as I already spent enough with this amp and a sub for her christmas present.  Thanks in advance guys!
DYohn
Platinum - Posts: 10,741
Posted: December 31, 2005 at 1:15 AM / IP Logged
You can purchase one far more cheaply than you can make one.  A Harrison Labs HP-Sub crossover module is a good choice.  Plus a passive subsonic filter would not only be expensive to build it'll eat up amplifier power.
black78ta
Member - Posts: 31
Posted: December 31, 2005 at 1:17 AM / IP Logged
Thanks, but I forgot to mention that I'm only going to be using 4-channel RCA cables for all four speakers and the amp is able to use the summed inputs to make channels 5 and 6 for the sub, so a pass-through type device wouldn't really work for my setup.
menace2sobriety
Silver - Posts: 394
Posted: December 31, 2005 at 6:17 AM / IP Logged
use a sealed sub box that way you dont need a subsonic filter.
DYohn
Posted: December 31, 2005 at 12:06 PM / IP Logged
Sure it would.  Just put it on channels 3 and 4.  But as mentioned above, you don't need one unless your sub is ported.
If you really want to build a passive subsonic filter, a high-pass @ 12db/octave with knee frequency of 20Hz for a 4-ohm woofer would require about 1400 micro-farads of capacitance and 45 mili-henries of inductance.  I'd expect you'll pay on the order of $250 or more to assemble those component values (and you'll have to build a capacitor array to get to 1400uf, and have a large iron-core inductor built to get 45mh.)  Here's your circuit:
making an external subsonic filter -- posted image.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
