best fm modulator
restepp25
Posted: January 02, 2006 at 4:09 PM / IP Logged
what would be the best fm modulator to get ? ive looked on ebay and found pyle, boss audio, kenwood, what would u guys recommend or what do u use ??
restepp25
Posted: January 02, 2006 at 6:06 PM / IP Logged
im talking about a wired one for an ipod.
kirktcashalini
Silver - Posts: 492
Posted: January 02, 2006 at 6:23 PM / IP Logged
what kind of unit you want the ipod to plug into, run a direct input if you can, dont bother with a fm modulator...
restepp25
Posted: January 02, 2006 at 7:33 PM / IP Logged
its an eclipse head unit, but the AUX input on the head unit sucks becasue u cant control the volume of the ipod with the head unit, you can only control the volume with the ipod, if i use a wired fm modulator i figured it would be the best bet as far as sound quality. and fm modulators are cheap so what should i get
LooneyG
Member - Posts: 43
Posted: January 02, 2006 at 9:29 PM / IP Logged
Maybe an iRiver FM Transmitter their fairly cheap and seem to work ok
restepp25
Posted: January 02, 2006 at 10:05 PM / IP Logged
i want a hard wired one.  which ones are good??
jm93030
Posted: January 03, 2006 at 1:27 PM / IP Logged
I’m also looking into modulator solution. I’ve used a few different FM wireless transmitters, but find the sound quality is too weak. Just read some very good reviews at Crutchfield and other sites on the Scosche FM-MOD01 Modulator. I’m thinking of picking one up at the local Wal-Mart and trying it out.
chigglefat
Posted: January 11, 2006 at 12:55 PM / IP Logged
Go with a switched FM Modulator, prefferrable the one made by Metra.  They have superior sound quality and a switch so you can disable it and get better radio reception.  All FM Modulators aren't alike, so chose wisely.  You can find the Metra Modulator at a local Fry's Electronics or at www.metraonline.com
Good Luck.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
