capacitors
nixon75
Member - Posts: 27
Posted: January 27, 2006 at 7:44 AM / IP Logged
help!! need diagrams on how to wire/install capacitors. thanks!
haemphyst
Platinum - Posts: 5,059
Posted: January 27, 2006 at 11:16 AM / IP Logged
Parallel. Simple as that. Be sure you charge the cap corrctly, I use a test light. Remove underhood fuse from it's holder, connect cap(s) and amp(s), place testlight in-line under the hood where your underhood fuse SHOULD be (and had better be). When test light goes OUT, and I mean OUT, re-install the fuse.
Battery positive to cap, onward to amp.
Chassis negative to cap, onward to amp.
(You can also run (effectively) from amp to chassis to cap negative also. Some installers will do it this way, I prefer the chassis-cap-amp method - shorter path to amplifier power input.)
