2 ohm stable
dubb
Copper - Posts: 52
Posted: January 30, 2006 at 3:38 AM / IP Logged
Let me start off by sayin Audiobahn subs really do brake easily. I have a quantum audio amp stable at 2 ohms 2000watt  @ 14.4 volts.  Can i run 3 kicker comp VR 15" 4ohm subs or will the load be under 2 ohms.
2005 Ford 500 SEL. 3 Kicker CVR 15"s. 2000 watt Quantum Audio AMP.
geepherder
Platinum - Posts: 3,668
Posted: January 30, 2006 at 12:22 PM / IP Logged
I believe those are dual voice coils, so if you wire the voice coils in series, and parallel the subs, you'll have 2.67 ohms which is fine.
kirktcashalini
Silver - Posts: 492
Posted: January 30, 2006 at 12:45 PM / IP Logged
lol, hilarious how you for no reasonmention how audiobahn sucks. I believe people need to look at product reviews, and read forums before buying audiobahn. I am also quite against audiobahn. I think you will be greatly satisfied with the VRs compared to the old junk a-bahns
dubb
Copper - Posts: 52
Posted: January 30, 2006 at 9:35 PM / IP Logged
Thank you guys..
notoriouswill
Member - Posts: 32
Posted: February 03, 2006 at 12:22 AM / IP Logged
Audiobahn is a good example of a good marketing team. That is the only thing that all audio companies want to copy from Audiobahn.
1 Memphis Mojo 15
1 Memphis 4000 watt amp
1 Memphis 75watt 4 channel amp
2 Memphis 6.5" MSQ's
2 ohm stable -- posted image.
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
