Briding Amplifier
smokinsmitty
Copper - Posts: 75
Posted: February 16, 2006 at 4:15 PM / IP Logged
OK my buddy wants to buy a 2 channel amp and bridge one channel so he can run 3 subs! Is this ok? Does it make it so the subs dont get the same amount of power? Just fill me in
1 15" Memphis Mojo,
Memphis 16-mc1000D amp,
Audiopipe 4gauge mp kit, Pioneer DEH4700MP head unit.
2002 Yamaha 660R Raptor
Yamaha FZR600 crotch rocket
Sea Doo XP800
Sea Doo Spi
tcss
Silver - Posts: 1,623
Posted: February 16, 2006 at 4:30 PM / IP Logged
Did you mean to say "bridge into one channel"? Because you cannot "bridge one channel"
There is no such thing as free installation!
smokinsmitty
Copper - Posts: 75
Posted: February 16, 2006 at 5:58 PM / IP Logged
umm well i'll explain here! ok he has a 2 channel amp and he is only going to bridge left channel! Is that ok?
1 15" Memphis Mojo,
Sea Doo XP800
Sea Doo Spi
j_darling2007
Copper - Posts: 210
Posted: February 16, 2006 at 6:13 PM / IP Logged
You can't bridge one channel. Bridging is combining the power of both channels into one.  If you are saying he is going to run 2 subs on one channel and one on the other, they will get roughly the same amount of power because the channel with the 2 subs with have half the resistance of the other ( if wired in parellel), causing it to get 2 times the power to be split between 2 subs.  However, they will have a higher THD.  However, this is not a very good way to run the subs. But it will work if the amp is stable to 2 ohms on each channel.
If I were your friend, I would save up for a mono sub amp that can run safely to one ohm, wire the 3 subs in parellell to get a 1.33 ohm load (if they are SVC) and run them like that.  He will be way more satisfied with the results.
There are 3 kinds of people in the world, those who can count and those who can't
