2002 Dodge Durango, separates
mmitt
Posted: March 08, 2006 at 4:23 PM / IP Logged
I am currently installing new seperstes in the front doors of my 2002 Dodge Durango and I was wondering if anyone knew how deep the space was between the door panel and the spot where the side view mirror is mounted?  I was looking at a pair of Alpine SPR-17LS speakers and I want to make sure the tweeter can be flush mounted before I purchase them.  Thanks.
mm
geepherder
Platinum - Posts: 3,668
Posted: March 08, 2006 at 8:58 PM / IP Logged
If you like them you should buy them.  Even if they won't flush mount to the factory sail panels, you can mount them close by or surface mount them.  There's always the option of adding onto the sail panels to make them fit (fiberglass).  Tack the tweeter pods where you want them with some superglue or something, stretch some grill cloth over them, then apply resin to it.  Once that dries, one layer of fiberglass will be more than enough.  Then just bondo, and finish them.  You can paint them, texture them, vinyl them, whatever.
Tuesday, September 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
