blowing my subs
the_one369
Copper - Posts: 80
Posted: March 15, 2006 at 9:29 PM / IP Logged
i have 2 12'' Alpine type R's and i keep blowing them. i am pushing each sub with a Kenwood KAC7201 at 4 ohms and the subs handle 500 rms and the amps put out about 470 rms what am i doing wrong??
DYohn
Platinum - Posts: 10,741
Posted: March 15, 2006 at 9:45 PM / IP Logged
How is your gain set?
the_one369
Copper - Posts: 80
Posted: March 15, 2006 at 10:37 PM / IP Logged
not quite all the way up but just below where they start to clip
lightdir
Posted: March 15, 2006 at 11:27 PM / IP Logged
what is the crossover frequency set at?
dragon51
Copper - Posts: 283
Posted: March 16, 2006 at 5:39 AM / IP Logged
The box size and type could also come into play
Francious70
Silver - Posts: 629
Posted: March 16, 2006 at 10:03 AM / IP Logged
Need more information like box size, type, bass boost?, crossovers, type of wiring, ect..
kfr01
Gold - Posts: 2,121
Posted: March 16, 2006 at 10:42 AM / IP Logged
You are:
1)  Clipping your amplifier badly, sending more than 500w to them, and not moving the driver enough for it to cool properly.
or
2)  Using a ported enclosure, not clipping your amplifier, but just hitting your sub's mechanical excursion limits...
or
3)  Both.
Read http://www.bcae1.com/ for information on gain setting.  Like another poster said, we need more information to help you.  Are you using a ported enclosure?
New Project: 2003 Pathfinder
the_one369
Copper - Posts: 80
Posted: March 16, 2006 at 12:51 PM / IP Logged
the power supply running to the amps is fine i have a volt meter and it is steady at 14.7-8 even when at a stop.  the box size is 1.25 cubic feet sealed which is the recommondation for the subs. the bass boost is off.  the frequency is set to about 55 hz
DYohn
Posted: March 16, 2006 at 1:02 PM / IP Logged
Sounds like you are clipping the amp, either with a bad input signal or an over-driven gain or both, and thus overpowering the speakers.  Plus, it may work for your setup, but 55Hz low-pass is pretty low... not that that will blow your speakers by itself, but it may be the reason your gain could be set too high.
forbidden
Platinum - Posts: 5,354
Posted: March 16, 2006 at 1:06 PM / IP Logged
Are your subs a single 4 ohm coil or a dual 4 ohm coil, if the latter, how are they wired?
Page of 3
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
