Battery Polarity reversal
coppellstereo
Silver - Posts: 785
Posted: March 28, 2006 at 1:54 AM / IP Logged
I just thought of this, couldnt yield a sucessful search query to find the answer:
Electricity 'flows' from negative to positive. Why then do we connect everything to the positive terminal?!
stevdart
Platinum - Posts: 5,816
Posted: March 28, 2006 at 2:25 AM / IP Logged
Which way does current flows
coppellstereo
Silver - Posts: 785
Posted: March 28, 2006 at 2:50 AM / IP Logged
Thanks!
'conventional current flow' - current flowing from higher voltage potential (+) to lower voltage potential (-)...in case that helps at all.
so what is another way to describe the other school of thought - negative to positive?
haemphyst
Platinum - Posts: 5,059
Posted: March 28, 2006 at 10:21 AM / IP Logged
In electron theory, current flow was explained to me this way: current is electrons moving from one atom to the next, without this "movement", you cannot have current. Electrons are negatively charged particles, and they want always to be in equal numbers on an atom. When there is a defecit of electrons, they will try to "borrow" electrons from neighboring atoms to equalize the atomic charges. They will move FROM the area of more electrons (the "more negative" area) to the area of less (the "more positive" area), voila! Current! AND the "negative to positive" phenomenon. The more electrons trying to move at one time from one point to the next, the more current produced. Current cannot occur, as you all know, without a circuit.
The movement occurs once there is a circuit. You CAN have voltage without current - it's called "static electricity". (Technically, a battery sitting with nothing connected to it, is "static" - potential without current) Static is used to describe an excess of electrons in one place or time, without current flow. Yes WITHOUT current flow. Once you make that spark when touching the door handle or while getting out of your car, it is no longer "static", as there is a current flow - the elctrons are equalizing! The spark is proof of this. And while there is no CONTINUOUS "circuit", for that brief instant of time, that is not "static electricity", there is current flowing.
Here appears to be a great little site with easy to understand graphics, yet fairly well described. I bookmarked it, 'cause I liked it so much Battery Polarity reversal -- posted image. . Here is what I searched for... Check out some of the links.
geepherder
Platinum - Posts: 3,668
Posted: March 28, 2006 at 7:37 PM / IP Logged
The reason we connect everything in the car to the positive terminal is because 99% of all cars are negative ground.  If your car was positive ground, everything would have to be connected to the negative terminal.  If that were the case, you'd also fuse the negative side instead of the positive side of the circuit.
stevdart
Posted: March 28, 2006 at 9:22 PM / IP Logged
Damn, haemphyst! you explained that well.
(...I still couldn't explain it, myself, but you linked some good info.  Can't blame anybody but myself if I don't get it!)
