Amp and Cap Drop Below 12 Volts
mobbmuzick
Posted: March 31, 2006 at 7:14 PM / IP Logged
First when i would turn my system up to a certain level the voltage would drop to like 9 and my 4ch and mono would cut out and when i turned it back down everything worked fine. My friend told me it was my battery so i went out and bought a optima yellow top. Now  at low volumes its like 13.5 but when i turn it up it still drops to 9 but it doesn't cut out. What did i do wrong that it's not a steady 12.
Headunit : Alpine CDA-9855
Speakers : Polk momo 6.5 Components
                     Polk DB 6x9
Amps: Infinity 7541a 4ch
      Alpine MRD-M301 Mono
Subs: 2x 10" mtx rt1004
forbidden
Platinum - Posts: 5,354
Posted: March 31, 2006 at 7:23 PM / IP Logged
Start by checking your grounds.
arrow12
Silver - Posts: 527
Posted: March 31, 2006 at 7:40 PM / IP Logged
What are the amp ratings for those amplifiers and what is the car?
That's my opinion. Take it, leave it, or correct me.
mobbmuzick
Posted: March 31, 2006 at 8:02 PM / IP Logged
it's a 97 accord ex. mono is 350rms at 2 ohms and the infinty is 111 x 4 at 4 ohms (which i highly doubt but thats what it says) thanks in advance
                     Polk DB 6x9
geepherder
Platinum - Posts: 3,668
Posted: March 31, 2006 at 9:41 PM / IP Logged
What is the voltage reading at the battery compared to the amps (across the amp power/ground terminals) under these conditions?
