Capacitor Quality and Manufacturers
vatodeth
Member - Posts: 8
Posted: April 04, 2006 at 7:33 PM / IP Logged
Is there a difference in quality between all of the manufacturers? I had read that a capacitor is a capacitor, that they all work the same and the only thing that matters is the Farad rating.
Is this true? Are low priced caps as good as expensive caps? I have also noticed that there are temperature ratings. What do I look for?
I have a 94 Blazer S10 with the 4.3L Vortec engine. I believe that the alternator is 100 amps. I am about to install a 450W RMS/800W Max MTX Mono Class D amp. I already have a 200W RMS (no max rating available) Yamaha 4-Channel amp.
Any other recommendations based on the vehicles alternator? Is a capacitor even necessary? Will a cap tighten the bass and improve performance?
Thanks to all who offer their opinion and assistance!
kirktcashalini
Silver - Posts: 492
Posted: April 04, 2006 at 7:46 PM / IP Logged
same engine and alt... you DONT need an alternator... do a search on this site also if you dont want to take it from me.
willdkartunes
Copper - Posts: 250
Posted: April 04, 2006 at 8:34 PM / IP Logged
I too have the same engine. As long as your battery is decent you shouldn't have a problem. A capacitor is not necessary. It is for glamour, not better sound.
Do whatever makes you happy in life without diminishing the happiness of others
stevdart
Platinum - Posts: 5,816
Posted: April 04, 2006 at 8:46 PM / IP Logged
Here's a thread and search that should answer your question.
vatodeth
Member - Posts: 8
Posted: April 06, 2006 at 1:21 AM / IP Logged
Wow! And I thought I was confused before!
I have mostly read this Flame War Thread! I got up to page 13 and then my brain hurt. What a battle!:
http://www.carsound.com/cgi-bin/UBB_CGI/ultimatebb.cgi?ubb=get_topic;f=1;t=022965;p=1
My conclusions are listed below:
1. The cap must have a low ESR (internal resistance) to be effective. The ESR must be lower than the vehicles battery! And then it's performance gains are only potential, not guaranteed!
2. The amplifier will have internal capacitors to store internal power for the amp caused by voltage spikes. A high quality amp will be designed properly. I know they ise large capacitors in high quality amps and I am assuming that they are for this purpose.
3. The cap will clean up the power supply to the amp, but is it really necessary if the amp already has it's own capacitors? This was my main reason for considering the purchase.
4. There seems to be a lot of evidence and people with hands on experience using a cap to solve the problme of dimming headlights. At this point I would recommend upgrading the vehicles power system, because using a cap is not a guaranteed solution.
I am not going to argue with anyone/everyone. I still want to perform a hands-on listening test, to see if I can detect any audible difference.
What I really want is a test that shows the db's and sound quality of the system with and without the cap. I really want solid, objective, quantifiable data to support or disprove the clean power benefits.
You would think that it would be fairly easy for someone to show us all what is really going on!
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: April 06, 2006 at 2:38 AM / IP Logged
1.  Exactly.  This is why digital caps are poor choices as ESR is usually increased.
2.  One thing Dan Wiggins once told me was that the location of those caps in the amplifier matters as well.  Many companies put large capacitors before the power supply where they can use lower power capacitors that are cheaper.  However putting them on the voltage rails is a much more efficient design.  From what he was saying, rail caps cost about twice as much, but provide about 4 times the performance for a given capacitance.
3.  Yes, because they aren't only there to clean up the ripple, but also to help prevent power supply sag.
