Suburban 2002 onstar mute
Jj2002
Posted: April 05, 2006 at 4:00 PM / IP Logged
Hello everyone
I have searched but have not found the answer. I would like to know how the onstar in a 2002 Suburban mutes the stock radio. The radio is a non RDS and has both a 21 pin and 9 pin plug. I have found harnesses and instruction for the rds radios (03 and up in GM trucks) but not for the non rds. I would like to use the same mute trigger for other audio sources(e.g., gps). Any help would greatly be appreciated, thank you.
sparkie
Platinum - Posts: 2,061
Posted: April 05, 2006 at 7:18 PM / IP Logged
The Onstar uses a data message through a wire to tell the factory radio to mute the front speakers and select the auxillary input audio from the Onstar and direct it to the speakers. I don't think you are going to be able to do it this way.
sparky
Monday, February 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
