LeSabre
msweeting
Posted: January 03, 2003 at 12:21 PM / IP Logged
Can anyone help witha 97 Lesabre car stereo install? What parts do I need? How do I remove the panels ? Can I use existing wiring?
The stereo is a Pioneer DEH-P740MP
Mark
Chris Luongo
Platinum - Posts: 3,746
Posted: January 03, 2003 at 9:52 PM / IP Logged
It's not a hard car, but the whole face of the dash from left to right has to come off---just allow yourself plenty of time to do it carefully.
You'll need an installation kit to mount the radio, a wire harness adapter (so you don't cut up the factory wires) and an antenna adapter (because GM antenna plugs are different).  The antenna adapter is a Metra 40-GM10, but I forget the numbers of the other parts.
Sometimes, the install kit will include instructions for the dash apart.  If not, this company called Scosche has a big book with radio removal information---if you have a friend who works at a shop, you might get to look at it.
Sound Pressure
Silver - Posts: 711
Posted: January 05, 2003 at 1:44 AM / IP Logged
http://carstereohelp.com/stereoremovalBuickLeSabre.htm
Sound Pressure
The Distortion
Copper - Posts: 50
Posted: January 05, 2003 at 7:24 AM / IP Logged
even though it says 94-97 does not mean it is only for a 94-97 Lesabre, it is the same exact, thing for a 93 Lesabre removal/install as well. I used that page  for the H/U install in my 93 Lesabre and those instructions are a perfect match, the interior has very slight cosmetic changes is all.
I just wanted to throw that in there for anyone's future reference :)
and if you run into any problems, feel free to ask If may be able to help since I have basically the same car , it is a pretty straightforward job so I doubt you will have any problems.
msweeting
Posted: January 05, 2003 at 1:07 PM / IP Logged
Thanks to Chris and Sound Pressure. Looks like enough to get the job done!
Sound Pressure
Silver - Posts: 711
Posted: January 05, 2003 at 9:53 PM / IP Logged
Glad to be of some help.
Sound Pressure
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
