2002 saturn vue, stereo wiring problem
redlite5
Posted: April 11, 2006 at 2:53 PM / IP Logged
i hooked up a kenwood stereo w/ removable faceplate in my 2002 saturn vue. but it would not light up. the cd player functioned, but did not play over the speakers. i did confirm that it was getting power and properly grounded. but the faceplate part doesn't do anythig. so after switching around the wires a bit. i was able to make it work, by attaching the red 12v and the yellow/memory 12v together. then the systems works fine. except for, when you turn of the car it does not go off. you have to turn the stereo off manually. it comes on with the acc. but stays on no matter what, until you tun it off. also you loss memory when you turn it off.
anyone have any ideas???
geepherder
Platinum - Posts: 3,668
Posted: April 11, 2006 at 6:38 PM / IP Logged
You need to check both your red and yellow wires in the harness.  The yellow wire needs constant power and is used to retain memory.  The red wire is for accessory.  There should be a few red wires in the harness adapter for your saturn.  You need to test which shows accessory power and use it.  If you're not showing proper power on both wires, check the fuses once you're sure there are no shorts.
redlite5
Posted: April 12, 2006 at 6:52 PM / IP Logged
hey, thanks for the reply. i tried all the hot wires. the yellow and the red. but, there is definitely something funky with the cars system. basically it seems as though the red 12v from the car is a dead wire. the yellow is hot and gives power to the stereo. but the red doesn't do anything. what i ended up doing for now was running the red 12v and the yellow memory from the radio to the yellow hot from the car. and that has it working. i will take the car to the dealer soon and have them run a check on the wiring. so, the red from the car is currently unattached. the only problem is that i have to turn the stereo off manually. it doesn't properly with the acc. so i see what happens. thanks for the assist.
geepherder
Posted: April 12, 2006 at 8:42 PM / IP Logged
I'm assuming you're using a harness, right?  Did you check all the red wires in it?  Did you check your fuses?  I own an 02 saturn sl2 and my car had an accessory lead at the radio.  Does the factory radio work if you plug it back in?
