MA Audio 5fard Cap Charge
Walkercustoms
Copper - Posts: 219
Posted: April 21, 2006 at 9:06 AM / IP Logged
I need to know if there is a way to charge this cap other then the bulb that was sent with it. the reason I ask is because the bulb was broken durning that great hurrican wilma and I need to recharge my cap. Does anybody know a way I can do this with out that bulb.
thanks
Wade
DYohn
Platinum - Posts: 10,741
Posted: April 21, 2006 at 9:24 AM / IP Logged
Use a standard 10 watt 20 ohm power resistor.  It can get hot so don't hold it with your hand.
geepherder
Platinum - Posts: 3,668
Posted: April 21, 2006 at 9:50 AM / IP Logged
I just use a test light.
Walkercustoms
Copper - Posts: 219
Posted: April 21, 2006 at 7:25 PM / IP Logged
How do you use the test light.
furflier
Copper - Posts: 236
Posted: April 21, 2006 at 9:46 PM / IP Logged
Run the test light in series with the power wire. Just like you would do with the charge lamp that came with the cap.
prophesybh
Copper - Posts: 78
Posted: April 21, 2006 at 10:31 PM / IP Logged
I just soldered a new bulb on mine
Don't Ask Questions When You Already Know The Answer!!!
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
