Dual Head Units
duoproductionx
Copper - Posts: 49
Posted: April 24, 2006 at 9:49 PM / IP Logged
im just curious who else is using dual head units, i have the OEM where it "should be", and my JVC AR 760 in my trunk securely mounted. do note currently the oem unit is essentially just a clock. but i have plans to have fun with it...
97 Monte Carlo
CDA-9885, PZI Crunch 5 channel,12in MB Quart Premium.
coppellstereo
Silver - Posts: 785
Posted: April 24, 2006 at 10:30 PM / IP Logged
why not take out the OEM?  It seems quite inconvenient to have the source unit mounted out of reach.
what fun is in store?
duoproductionx
Copper - Posts: 49
Posted: April 24, 2006 at 10:49 PM / IP Logged
you have 3000 dollars of car audio stolen from your car, plus having to cover a new dash, window and seats; and see if you ever mount a head unit in the dash again
97 Monte Carlo
forbidden
Platinum - Posts: 5,354
Posted: April 24, 2006 at 11:05 PM / IP Logged
And the guy that follows you home from the contest you were in or the guy that heard your $3K system that followed you home would instantly know to look in the trunk. No offence intended but if I can pick out something like this, imagine how a thief would think about it. Nothing is safe. An alarm and insurance is your best bet.
duoproductionx
Copper - Posts: 49
Posted: April 24, 2006 at 11:12 PM / IP Logged
i sure hope hes got the power tools to do it then....its not the easiest head units to steal when bolted to the frame of the car, then welded in place. sub boxes are mounted to the cars frame as well just not quite as well.
97 Monte Carlo
323gtx
Member - Posts: 12
Posted: April 24, 2006 at 11:13 PM / IP Logged
Insure vehicle, buy an alarm, remove your HU faceplate, and shave trunk lock. Has worked for me.
Mazda 323 GTX +
330 lbs. glass +
4, 5 gallon buckets resin +
1600w RMS @ 1ohm = 162.3db
duoproductionx
Copper - Posts: 49
Posted: April 24, 2006 at 11:50 PM / IP Logged
i was insured at the time, didnt cover a penny of it. i do keep the faceplate off, have an alarm(and no i didnt wire it like every other idiot does). one day ill go back to indash, but besides, its nice to make a coupe into a for sure 2 seater.
97 Monte Carlo
Tuesday, October 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
