guage power wire?
eljay8619
Member - Posts: 16
Posted: April 27, 2006 at 10:37 AM / IP Logged
okay im about to install my new alternator(130 amps: 70 amps idle) and i want to know which power wire im i suppose to change to a higher gauge power wire? and they told me i should change it to a 4 gauge power wire. sounds right?
arrow12
Silver - Posts: 527
Posted: April 27, 2006 at 4:03 PM / IP Logged
Check the Power and Ground link to the right.  You should be fine though.
That's my opinion. Take it, leave it, or correct me.
geepherder
Platinum - Posts: 3,668
Posted: April 27, 2006 at 6:28 PM / IP Logged
There'll be a stud on the back of the alternator (which may have a protective rubber piece over it) which will have a wire going to it which comes from the battery.  That's the wire you want to upgrade.
eljay8619
Member - Posts: 16
Posted: April 28, 2006 at 2:03 PM / IP Logged
ok thx
Hornshockey
Silver - Posts: 520
Posted: April 28, 2006 at 7:18 PM / IP Logged
I would read DYohn's sticky on upgrading the big three at the top of this forum; upgrading the power wire from alternator to battery doesn't do you much good unless you also upgrade the ground wires.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
