99 Lexus GS400, system, wiring
silver_gs
Member - Posts: 15
Posted: May 02, 2006 at 3:47 PM / IP Logged
I need some help swapping out the Nakamichi HU in a 99 Lexus GS400 with a Pioneer AVIC-D1.  I want to keep the swap as simple as possible.
I looked at the wiring diagram for replacing the HU and am still in the dark on how to do this myself.
1. Is this the correct diagram http://lexusmodz.netfirms.com/GS_DIY/stereo/  ?
2. Is there an even more simplified version of that wiring diagram?  I want to replace my NAK HU with a Navigation system (Pioneer AVIC-D1) and was wondering what (if any) I need to buy in terms of a wiring harness or (anything else) such to connect the nav to the existing amp in the trunk.
In short I need some help making this DIY task as simple as possible so that even a simpleton like myself can do this at home.
I know that I have to hookup the speed sensor to the appropriate wire in the car and I noticed another DIY on the website linked above http://lexusmodz.netfirms.com that identifies that cable behind the instrument cluster - so I think I can get to that one.
Found this page here that has a description of the wires, but this is still foreign to me!  :(
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1999&make=Lexus&model=GS300/400&ID=18201&type=Stereo
Can anyone make this simpler for me please?  I can't afford to pay a professional to do the wiring, so need to figure this out myself.  I will be eternally grateful to anyone who can help me with some guidance and tips.  If you are in town, I will even give you a free meal to install it for me at my house in your free time.  :D
Better yet, if I am brave enough I could swap out the factory amp and install a better after market amp and speakers while I am it, but that is just wishful thinking.  I need to hook up the nav as my first priority.
kps67
Member - Posts: 25
Posted: May 03, 2006 at 10:47 AM / IP Logged
What exactly do you need help with. If it is a D1 and you have a double din opening where your factory Nakamichi HU was then you will not need an dash kit for the installation. You will probably want to buy a wire harness for your vehicle that way you do not have cut your factory haress to connect the AVIC-D1 to your vehicle. The harness makes it possible so you can match up the colors on the back of the aftermarket unit to it and then once you finish connecting all the like colors it will plug right into the harness that you inlugged from the back of the factory HU. After that you still ahve to mount the gps antenna and find all of your other connectionon your own. Such as parking brake wire, Speed sensor wire, reverse light wires just to mention a few. If these instructions dont help you any you may need to take it to reputable shop in your area and let them do it so that you dont mess your vehicle or your navigational unit up.
Owner/Installer for Tricked Out Motor Works
Moderator - Posts: 12,488
Posted: May 03, 2006 at 11:41 AM / IP Logged
silver_gs, the installation will require you to either rewire new speaker wires from the D1 to the speakers or you can use a Soundgate XR4 module.
silver_gs
Member - Posts: 15
Posted: May 03, 2006 at 12:01 PM / IP Logged
Yes my Nak HU is in a double din opening
I know where the speed sensor wire and parking brake wires are.  I don't have a backup camera, so will not bother with the reverse light wires at this point.
The bottom line is that I have to do this myself as I simply can't afford to take it to a professional in as much as I would prefer to do that.
I am sure with enough direction I can do this myself.
Hmmm......  perhaps I need to find one of these modules.........
So far this is what I have found in my research:
There are 4 connectors that plug into the back of the factory amp. One plug has only 2 wires that go through it. That is the plug for the subwoofer
Black wire = +
Red wire = -
Now we move onto the big plug to the right of that one. This has all the speaker outputs.
Front Right speaker
Green = +
Blue = -
Front Left Speaker
Pink = +
Purple = -
Rear Right Speaker
Red = +
White = -
Rear Left Speaker
Black = +
Yellow = -
That blue / YELLOW wire is a 12v constant. It always gets 12v even when the key is off. The cigarette lighter can be used for the accessory turn on lead.
Do I need to buy a tester and any other "tool".
extreme1
Silver - Posts: 1,070
Posted: May 03, 2006 at 1:38 PM / IP Logged
Reverse is also used to keep the map from flipping around when you are backing up.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
silver_gs
Member - Posts: 15
Posted: May 29, 2006 at 12:09 PM / IP Logged
Car is a 1999 Lexus GS400
Audio equipment is as follows:
HU - Pioneer AVIC-D1 navigation system
Front component speakers - Seas Excel W15CY-001 (E015) 5.5" - but the older model in 6.5" - http://www.madisound.com/cgi-bin/index.cgi?cart_id=2241445.11217&pid=985
No rear speakers as I want to keep the sound stage at the front of the car
Tweeters: NeoCd3.0M 3" Ribbon Tweeter http://www.madisound.com/cgi-bin/index.cgi?cart_id=2241445.11217&pid=2139
Subwoofer : Focal Utopia 27WX 11 inch sub
Component Amp: Zapco Competition series - C2K - 2.5X http://www.zapco.com/prod/comp_prods/c2k25Frame.htm
Sub amp: Zapco Competition Series - C2K - 2.0X - http://www.zapco.com/prod/comp_prods/c2k20Frame.htm
Three SymbilLnk cables.
I don't have any crossovers and I was wondering how to physically wire these up - specifically the wiring of the amps and speakers:
I have already hooked up the navigation system (and it works flawless other than no audio as I still have to wire up the rest of system) and ran RCA cables for the speakers (front, rear and sub) all the way to the back. So my questions focus from that piont forward.
1. What is the basic path to follow from the beginning - 4 guage wire from + terminal of the battery all the way to the speakers in the doors.
Here is what I think I need to do:
1. Power cable from + side of battery
2. cable above connected to plus side of capacitor
3. cable from negative side of capacitor to ground
4. One connector from power distribution block to + side of sub amp
5. Second connector from power distribution block to + side of components amp
6. rca connection from front speaker output on nav to input side of components amp
7. rca connection from rear speaker output on nav to input side of components amp
8. rca connection from sub speaker ooutput on nav to input side of sub amp
9. run wiring from components amp to crossovers and the to front speakers and tweeters
10. run wiring from sub amp to subwoofer
All negatives for the amps grounded
Here are pics of the amps connections (C2K - 2.5X) - How would I configure the amps to send their output correctly to the front speakers and tweeters when there are no crossovers?
Looking at this pic of the amp, there is a crossover select switch at the top left. So I guess I don't really need to use crossovers, but then how would I wire the tweeters and speakers from the amp?
99 Lexus GS400, system, wiring -- posted image.
C2K - 2.0X
Please confirm my wiring path and the questions regarding how to wire up the system. I am in over my head, but just can't afford to hire a professional to do this for me.
I think with guidance from the gurus on here, I can do this! I have looked at the amp manuals and I am still in the dark - [url]http://www.prudensconsulting.com/yahooitems/C2K_2.0X.pdf[/url]
I made an amp rack from 3/4 inch high density MDF and will be bolting that to section behind the rear seats - see this pic for reference: (this is looking into the car from the rear. You can see the nav installed if you look at the dash)
I have tons of sound deadening that I will install also. I also have to figure out where to install the subwoofer. If you look at the pic above the stock sub is on the rear parcel shelf, however that shelf is flimsy thin piece of metal and will not support the sub in a box (I bought this box for it (see below). If you look directly behind the rear seats in the trunk, you can see a raised area where I can install the subwoofer box, however my rear STB (strut tower bar) is in that spot. Any suggestions on how to install the sub box other than having to reinforce the rear parcel shelf and just complicating this install further?
This is the wiring I bought (already used up the RCA cables running from the pre-amp RCA outs on the navigation system). You can see the pic of the 4-gauge amp kit I got (and the rear view camera at the top - got that working very well already)
silver_gs
Member - Posts: 15
Posted: May 30, 2006 at 9:36 AM / IP Logged
Anybody?   I am sure someone can help me out here........
geepherder
Platinum - Posts: 3,668
Posted: May 30, 2006 at 8:26 PM / IP Logged
Since you have no passive crossovers for your speakers, set the crossovers in your deck to high pass around 80-100 Hz (about where you'll crossover the sub)front and rear- this will be your starting point.  Set the crossovers on the 4 channel amp to around 2.5 kHz for starters, with the tweeters on high pass and the midbass drivers on low pass.  A cd with multiple test tones will help you locate your crossover points, as well as setting gain.  Just run your speaker wire from you amp directly to your speakers.
It looks like you've got a grasp on the basic hook up.
Why do you feel the need to secure your box to the rear parcel shelf?  Why not just secure it underneath?  Just be sure of where you drill so as not to punch a hole in the gas tank or anything.
silver_gs
Member - Posts: 15
Posted: May 31, 2006 at 9:20 AM / IP Logged
I have absolutely no idea how to do that.  I have also gone through the manual and don't see anything like that.   Here is a pdf version of the operation manual - perhaps you can point out the obvious to me please - http://www.prudensconsulting.com/docs/AVIC-D1_Operation_Manual.pdf
Is this the button at the top left of the amp pic I posted above?
So which connections on the amp would I run directly to the tweeters?  I am confused about which specific connections on the 4 channel amp to run to the front mid bass drivers and which connections to run to the tweeters......
The rear strut tower bar is there in that location and there is not enough space between that and the back of the rear seats....
geepherder
Posted: May 31, 2006 at 7:26 PM / IP Logged
Chapter 8 goes over the audio controls on the deck.  Scroll down to where it says "Using the high pass filter".
http://www.zapco.com/prod/comp_prods/documents/C2K_Contents_Manual_B.pdf  Scroll down to where it says 4 channel amp controls.  The different controls are numbered, with descriptions of what each control does on the next page.  The front and rear frequency range buttons should both be pushed in so that you're on the crossover high range.  The pictorial will give you an rough idea of where to set the crossover frequency knobs front and rear, which you can check with your test tone cd.
You connect the tweeters to the speaker outputs.  If you use the front inputs for the tweeters, then you'll connect them to the front speaker terminals.  If you use the rear inputs for the tweeters, you'll use the rear speaker terminals.
I'm not telling you it has to go where the strut tower brace is.  Why do you feel it must be secured to the rear deck?  Just place it in the trunk and secure it in place.  It doesn't have to go all the way back.
If there's anything here you're still not sure about after reading all this, have a friend that's done this before help you, or wait until you can afford to have it done (even if it's just a little at a time).  Otherwise, you could easily mess something up and see those hard earned dollars of yours go to waste.
Sunday, November 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
