Constant Crackling?
hattster
Member - Posts: 10
Posted: May 15, 2006 at 7:34 PM / IP Logged
Hey im pretty new here but I see there are quite a few smart poeple that maybe could give me some help with my problem. Just recently my two rear speakers in my 2002 alero started crackling none stop even when I turn the deck off and the car is still on both speaker with crackle. Also when I turn the music up some once in awhile there will be a loud static noise that come and goes. It has a new deck and relocation harness but has worked fine for months this problem has just come up.
Please help me as soon as posible im going on a road trip and need my spekers
darthness
Copper - Posts: 136
Posted: May 15, 2006 at 8:02 PM / IP Logged
speakers are probably blown.
hattster
Member - Posts: 10
Posted: May 15, 2006 at 11:30 PM / IP Logged
yah but my music wasn't even loud also why would both blow at same time. I have had my music way louder with no problems
forbidden
Platinum - Posts: 5,354
Posted: May 15, 2006 at 11:35 PM / IP Logged
Run that by me again, the deck is turned off as in power off or just turned off as in volume down? Does this crackle only happen on cd or on am/fm as well? Is there an amplifier on the speakers? List absolutely everything that was done please.
hattster
Member - Posts: 10
Posted: May 17, 2006 at 5:23 PM / IP Logged
Yes there is a AMP on the speaker through the monsoon system. And that crackling is constant as long as the car is on and there is power to the speaker. on am/fm and cd and when the deck is totally off.
mustangfoo
Silver - Posts: 371
Posted: May 17, 2006 at 5:34 PM / IP Logged
sounds like you have a wire touching, check your cables starting from the speakers going to the amps.
hattster
Member - Posts: 10
Posted: May 17, 2006 at 6:35 PM / IP Logged
nope no wires touching
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
